Alternator Bracket pics needed
The arm that I got looks like this one..... http://cgi.ebay.com/ebaymotors/New-C...Q5fAccessories
Here is how the brackets were arranged when I got the car, and it was all sorts of messed up. What am I missing here...since the washers on the bracket are NOT the look I am after.
Deja
Deja
Were you to remove ALL those washers, intall the lower mount directly to the head, and locate the upper mount to the rear of the alternator, things should line up as they are supposed to.
The only problem might be that if your WP has been changed to a non-vette WP.
As far as the new piece you've bought? Return it. I had that same POS on my car, and it went into the trash for a good reason....
Say the arm gets relocated behind the alt ear and most washers removed, isn't that going to setback the alternator's pulley and throw the alignment?
Can't say for sure but it looks like the WP & crank pulleys line up. Noticed the upper rad hose takes the scenic route to the radiator, too.
Fixin' Bubba issues are always a challenge, eh?
In your case, they've used the stack of washers to push the entire alternator forward and align the pullies. In the other case you just relocate the entire alternator forward without the washer stack to align the pullies.
Either way, if the pullies are aligned, the alternator sits in the same spot (front to rear).
If you really want to firm things up, you can put the J-bars on both sides of the alternator.
I bought an aluminum water pump pulley, a 3-groove crank pulley, and will be rectifying the washer setup, so hopefully this will entirely eliminate the problems that I have been experiencing. I don't have AC, so one of the pulley grooves will be left open, but that's no biggie. Short of getting a new power steering pulley, messing around with getting the old pressed on pulley off, yada, yada, yada....that will be the best solution here.
And DANG those pulleys areexpensive. I should have just gone with a Gilmer setup right from the get-go, but belts are not readily availble for that setup. Maybe if I win the lotto....
I'll post pictures with the setup all mounted this weekend. Thanks everyone for the photos, it's really appreciated!!!!
Deja
The reason I ask is because I have had so damn many power steering issues with the belt flying off.... the most recent being that the stud on the back of the pump snapped off
I already have a new pump but I was going to modify the tension retaining system myself in a non-bubba way (machine shop and all) If all three of my belts went up over the water pump that would seem exceptionally solid to me.I have plenty of clearance between my Rad and my clutch fan, and want to give this a shot. Please object if you foresee any problems, like triple rpm belt interference based on the loads of the accessories and what not... I dont want do destroy belts or accessories!
). My hypothesis was that the third point of contact across from the point of tensioning would actually stabilize the system by eliminating excess up-down travel of the elastic belt, much like a serpentine is stabilized by all sorts of pulleys. Just a hypothesis but please explain your reasoning by gentler curve
