Help, my tach needle has gone nuts!
Old Jan 29, 2010 | 06:16 AM
C3smallblock's Avatar
C3smallblock
Default Help, my tach needle has gone nuts!
Just tonight my tach needle has started flicking down rapidly then correcting itself before flicking down again. It has pretty much gone mental! Any ideas on where to look for the problem? I guess it is a problem in the tach mechanism which means pulling half the car apart, but if there is anything easier to check first I would appreciate any advice.
Cheers
Kev
Old Jan 29, 2010 | 09:31 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Probably a bad tach board.
Old Jan 29, 2010 | 02:59 PM
C3smallblock
Where is that located? I am guessing on the back of the gauge?
Kev
Old Jan 29, 2010 | 07:32 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default tack board
yep, 75 was the first year for the electronic tack. Another component is the filter for the electronic tack.
Old Jan 29, 2010 | 07:49 PM
Golden's Avatar
Golden
You might want to check the top of the coil and the coil lead.
An ignition short across the top of the coil can cause electronic rev counters to go mad
Old Jan 30, 2010 | 12:02 AM
C3smallblock
Well the plot thickens!
I just went to take the car out today and the main drive belt was screaming a bit (and the needle was still freaking out). So I shifted the alternator to take up the slack on the belt and now the tach is working fine again???
Coincidence or related?
I also hit a bump and bottomed out today and cracked my manafold in half, but that is another issue
Kev
Old Jan 30, 2010 | 03:36 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Check the tach filter! It is common for the wire to break or come loose at this filter. Your bump may have jarred it enough to make good contact. If this is the problem sometimes a drop of solder in the end will be enough to make good contact again. It is pictured below and shown in gray.
If this is the problem and solder won't work, we have them in stock. http://willcoxcorvette.com/advanced_...=tach%20filter
Willcox
Old Jan 30, 2010 | 03:51 PM
C3smallblock
Thank you, I will check the filter today.
Kev
To Help, my tach needle has gone nuts!
