Anyone know a good source for right angle heater hose fittings for 3/4 and 5/8 hose that are not plastic?
I'm looking for hose barbed right angle metal fittings?
I can get plastic ones at the local auto parts store, but not metal. Just not sure of the durability of the plastic ones over time. Don't want to overheat the LS1 after this much freakin' work.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Are you trying to make up the water pump connection to your LS swap?
I wound up making my own elbows out of brass fittings.
If that is not what you are wanting to do you might check with Jags That Run for what you are looking for. You might have to call them and tell them what you are looking for.
Yes Sir: I used PEX brass W/ barbs water pipe fittings. 1 inch for the 3/4" & 3/4 inch for the 5/8 " sizes. You can buy them @ Lowes or Westlake Hardware. Running these for the last year, No Problems. Have a great one. Gene
If I am understanding what you need correctly, have you considered just picking up molded heater hoses?
The hoses I am using have a 90 about 6" from one end, and are otherwise just straight hose.
Yes Sir; I put stainless steel clamps on them, barb about the same depth, as the clamp. I also used the Pex valves on the heater shut offs. My understanding is the radiator only has Approx. 15 Lbs. the plumbing system has minimum Average of 60 Lbs to 225 Lbs. Max. I know there smarter guys on here than me, maybe they will give you some better answers. Have a great one. Gene
All 68-82 air conditioned Vettes used heater hoses that were molded. One hose has 90 degree bends molded in both ends of the hose, and one just has a 90 on one end. The factory needed the 90's to connect to the core without kinking, too. These hose sets are available from any of the Vette vendors for about $45 for the pair.
