Help...Ideas needed?
Old Jan 30, 2010 | 04:16 PM
DO2G's Avatar
DO2G
Default Help...Ideas needed?
I used the Harmonic Balancer Installer from Autozone. Now the insert from the kit that goes into the crank snout is stuck. It's flush with the balancer so I can't get a good grip on it. Any ideas how to get it out?
Old Jan 30, 2010 | 04:51 PM
snoopykissedlucy's Avatar
snoopykissedlucy
Rule #1 coat every piece of the installer in anti-seize compound.
Since you're already there....I say use an impact driver. It's like a screwdriver that you use a hammer on. As you strike it, it rotates the bit clock-wise or counter-clockwise.
(I'm assuming the stuck insert is screwed into the crank nose)
You will wind up damaging the bit but dont worry, Auto-zone never checks their loan a tools....I know because they look like crap when I check them out.
http://www.harborfreight.com/cpi/cta...emnumber=37530
Old Jan 30, 2010 | 04:56 PM
DO2G's Avatar
DO2G
Yes, the stuck insert is screwed into the crank nose.
Old Jan 30, 2010 | 05:08 PM
snoopykissedlucy
Another idea, go get a screw extractor. It looks like crap but they actually work...just take your time. (It's basically a reversed drill bit)
http://search.harborfreight.com/cpis...crew+extractor
Old Jan 30, 2010 | 06:33 PM
72LS1Vette's Avatar
72LS1Vette
You could either heat the balancer with a propane torch or spray some freeze spray on the insert to get a little clearance. I would try the freeze spray first. If you need a combination of the two, heat the balancer toward the outside edge and then freeze-spray the inner part of the insert. I wouldn't worry about wrecking an AutoZone tool. Most of the ones that I have rented have had unimagineable things done to them already.
Rick B.
Old Jan 31, 2010 | 12:21 PM
DO2G's Avatar
DO2G
Used a screw extractor and it worked perfectly. Thanks for all the ideas.
To Help...Ideas needed?
