Engine ID
Old Jan 31, 2010 | 11:47 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Default Engine ID
I've been told that my engine is out of a 70 Corvette (chassis is 74).
The engine has 3970010 on it, so this is little help to me, seems GM used that ID for a load of V8's
The block has been decked, so the front engine pad just shows "151429967" and is pretty faint.
What is that number? Are there other numbers elsewhere that might help?
Old Jan 31, 2010 | 12:01 PM
SoCalErv's Avatar
SoCalErv
Army
That particular block was used for many years including 1974.
To determine the year look at the casting date located on the passenger's side on top of the transmission bell housing mounting flange. At least you will know when the block was cast.
The VIN you posted I could not find a reference for. Maybe someone else can help you.
Old Jan 31, 2010 | 12:15 PM
Mike Ward's Avatar
Mike Ward
Those numbers are kinda sorta like a Corvette VIN derivative- if the 5 is actually an S.
Does the VIN on your car end in 429967?
Old Jan 31, 2010 | 09:38 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Looks like a 5 to me, but it's pretty faint.
No, but I don't expect them to match as I was told the engine is from a 1970.
Old Jan 31, 2010 | 09:39 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
K10, does that make sense?
Old Jan 31, 2010 | 10:15 PM
Mike Ward's Avatar
Mike Ward
K10 would be November 1 1970. If it were a Corvette block, it would have gone into a '71 MY car. The VIN derivative would read 1S1XXXXX which is why I asked if the 5 on yours was actually an S. In any case the final VIN for a '71 ended in 1S121801, and your stamp is 429967, so no dice there.
Dunno. Got a pic?
Old Feb 1, 2010 | 07:15 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Yep.
Old Feb 1, 2010 | 08:58 AM
avner's Avatar
avner
It's not look like original stamp.
Someone shave the original stamp and make a poor stamp instead.
Avner
Mike Ward's Avatar
Mike Ward
Must be a rebuilder's number.
Old Feb 1, 2010 | 10:37 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
I was told it was a rebuild engine, so that makes sense.
Other than Nov 1970 and generic GM SBC, is there any way to narrow down where it came from?
It could very well be a 70 block with heads from X, intake manifold from Y.
Intake manifold has a series of numbers, are they of any use?
I'll remove the valve covers and check the number in there as well, perhaps that will at least give me a better idea of what I've got.
Old Feb 1, 2010 | 11:39 AM
Mike Ward's Avatar
Mike Ward
Without a teardown you wont know what pistons or cam are in there, so pretty difficult to guess what the engine might be today or what it used to be.
To Engine ID
