I need to get new rotors for my 76 since mine have developed grooves in them. I was wondering what are some good rotors and where to get them at a decent price. My car is mostly a weekend cruiser with some autocross duty. It may become my full time autocross car if I can't figure out what is going on with my 73. I want solid rotors. There is no need for slots and drilled are too dangerous for racing. I just want some replacement rotors that will stand up to Hawk HPS brakes and will not crack or warp.
I dont' want to spend over 150 for a set of 4 and prefere to buy American. I have done some searching and found Muskegon Brake has a set of 4 for $99.95. Where are these made? Has anybody had any problems with those rotors? The cheapest ones i have found that say Made in America are $70 each. Anybody know where they have the best deal? I am not exactly cheap, but I am trying to save up for a house and want to spend as little as possible.
Also, another question is what is the difference between the front and rears? They look the same to me except the rears have more holes in them. Are they different because of the parking brake?
Thanks for any input.
Easy Mike
close
- Member SinceJun 2000
- LocationSouthbound
- Veteran Field #1Cruise-In II Veteran
Liked:1,481 Times in 1,257 Posts
If they're not too badly scored, you may be able to turn your stock rotors. Have you miked them?
Check our favorite intergalactic auction site, I got a smokin' deal on AC Delco front and rears...I think the name was 'thepartslady'
The rotors on sale are NOT made in the USA, but are quality rotors. It is hard to get an affordable rotor made in the US. I do have USA made rotors with the correct rivet holes for $75.95 ea.
Quote:
They are really bad. It almost looks like a rock got under the pad and put about a 1/4" groove all the way around the rotor. It is on both right side rotors. I am going to go ahead and replace all 4, but will keep the two lefts for spares.Originally Posted by Easy Mike
If they're not too badly scored, you may be able to turn your stock rotors. Have you miked them?I do not want drilled or slotted. There is no advantage to either except a little bit of weight savings. My dad is a brake tech for Bosh at their proving grounds and have seen or done tests with all kinds of rotors. New style pads do not gas up like the old organic pads do, so there is no need to have the slots in there. I have seen drilled rotors crack after a day at the track. The only reason to have slotted or drilled are for looks, and on my car I don't care about looks.
ExploreQuote:
Your dad is a very smart man. Nothing like the voice of experience. Originally Posted by vettehardt
Get the best rotors you can find. Be aware that they will need to be checked for runout once installed and then corrected as required. Try to get runout below .003"
Peterbuilt
close
- Member SinceAug 2006
- Locationmount holly NC
- Veteran Field #12025 c3 ('74-'82) of the Year Finalist - Unmodified
- Veteran Field #22019 C3 of Year Finalist (appearance mods)
Liked:1,552 Times in 1,161 Posts
Before you remove the rotors you might want to check them with a micrometer, the minimum thickness is stamped on the edge but I think it is 1.215.
Next you can check that both sides are parallel to within .001.
The groove may not matter, see: www.oeqf.com/techinfo/index.htm
If you decide to try and apply a non directional finish before replacing your rotors mark one hole on each rotor and the lug it came off of so each rotor goes back on the same wheel in the same position.
I'm not sure but I think the front and rear rotors are the same except for the parking brake hole, those that know better can correct me.
Keep saving your money, it's a good time to buy a house.
Quote:
The rotors are different and not interchangeable. There was a member here call mrgofaster that found out the hard way.
Peterbuilt
close
Quote:
Hi Mike, now that you mention it I remember Mr. Gofasters posts, your right he put the fronts on the rear and the depth of the 'Hat' is different. Wonder if he ever got his Vette on the road? His videos were entertaining. Thanks for clearing that up.Originally Posted by Mike Ward
Really, I've run drilled rotors in super coupé circuit racing on slicks and not had them crack. Do you guys make rotors out of cheese?Originally Posted by vettehardt
theandies
close
- Member SinceJun 2001
- LocationVirginia USA
Liked:1,058 Times in 756 Posts
Quote:
Considering that the rear rotors actually have a small drum built in for the parking brake I'd say they are different. While you have your rears off you might want to inspect all the drum hardware and change over to stainless steel hardware if needed. One of the big problems with the parking brake not working is rust causing the mechanism to freeze up.Originally Posted by Mike Ward
Easy Mike
close
Quote:
Excuse me, but rotors made in the U. S. of A. are made of American cheese. None of the furrin stuff.Originally Posted by Mike Ward
Yes, swiss cheese. It comes pre-drilled.
Quote:
I'm sorry but I have to disagree with you...Originally Posted by Easy Mike
French cheese is the best of the world...
mrvette
close
- Member SinceJul 1999
- LocationOrange Park Florida
Liked:230 Times in 209 Posts
Brie with crackers and wine....Originally Posted by 73StreetRace
I'm sorry but I have to disagree with you...French cheese is the best of the world...
As to the rotors, try NAPA, I found them there for a shockingly lo price, the box did say USA on it, but for 30 bux each I can't see how either.....
and yes the difference is a GM goof up, the rotors are identical appearing except one spot, and it's sneaky....the thickness of the top hat flange area that contacts the hub....rears are thinner than fronts by about 1/8 inch....the rotors I have seen have the ebrake area similarly machined, dunno why, just is.....the rotors were perfect in runout.
