Caliper bleed order
Old Feb 4, 2010 | 09:51 AM
iceref63's Avatar
iceref63
Default Caliper bleed order
I have to rebuild by rear brakes and need to know the order to bleed each rear calliper. There are 3 bleed screws on each rear caliper. I read the sticky but could not determine the correct order and my manual does not address either. Thanks in advance
Old Feb 4, 2010 | 10:01 AM
wombvette's Avatar
wombvette
It really makes no difference. Just the upper ones though. The lower is a stopper.
Old Feb 4, 2010 | 10:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
GM service manual says:
Left rear inner
Left rear outer
Right rear inner
Right rear outer
Right front
Left front.
I have bled the system beginning with the right rear inner half and not had any problems.
Old Feb 4, 2010 | 11:24 AM
hugie82's Avatar
hugie82
I was always taught you start from the farthest point from the master cylinder and work you way in.
Old Feb 4, 2010 | 12:45 PM
midyearvette's Avatar
midyearvette
....however you can do it the reverse way and it seems to work too.....the lower bleeders on the rear are plugs and do not bleed the system as stated earlier by wombvette.....
Old Feb 4, 2010 | 04:57 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
To Caliper bleed order
