Composite Monospring front & rear?????
http://www.vettemod.com/forum/showthread.php?t=2302
If you want a nice ride but you want it to handle, go big on the front sway bar. And get a decent rear sway bar to match. But go a little softer on the springs.
I think something that isn't clear to many people is what independent suspension really means. It a rather poor term because it implies movement of one side doesn't affect the other. However, that isn't how it's used. As the term is used on cars it means geometric motion of one wheel doesn't change the position (caster, camber, etc) of the other wheel.
However, all cars for the most part WANT some level of interaction between the left and right wheel. That is exactly why we have anti-roll bars. An anti roll bar effectively transmits forces from one side of the car to the other. This system does the same thing. The only difference is it doesn't look like a traditional U shaped anti-roll bar.
Yes, the transverse, dual pivot leaf spring does provide some anti-roll effect (the rear springs on the C2-C4 were truly left to right independent as they were rigidly clamped in the center). However, those forces can be calculated and worked out into a roll rate. Once you know the roll rate contribution of the leaf spring it is simply added to the roll rate due to the anti-roll bar and you now know the total system roll rate.
The system is miss understood but actually is an excellent design. The one and truly only killer flaw, the reason why just about every car doesn't use this system, is cost. The fiberglass spring is simply more expensive. Yes, it saves weight and in some cases packages better than a coil spring. However, in most cases the cost benefit analysis kills it in favor of traditional coil springs.
On the downside it links both sides of an independent suspension system and brings with it all the issues that the invention of independent suspension was designed to eliminate. I'm sorry BTAL, the compression on one side of the spring will definitely impact the other side, in fact I suspect it's a design feature to reduce body roll.
I'm saying that from the point of view of the tires, they don't know or care what combination of springs are pushing them against the road. In the end the spring loads on the tires can be thought of a wheel rate and a roll rate. It doesn't mater what the linkage and springs look like. Now in the case of the Corvette the ride spring rate is mechanically coupled to the other side of the car. However, we basically have the exact same thing with a conventional coil spring setup. I compress the left wheel. That twists the anti roll bar and which then pushes up on the suspension on the other side. Net result, the instantaneous spring rate acting on the other wheel is reduced.
The long and the short of it is there is no fundamental dynamic disadvantage to the leaf spring as used on the Corvette. That doesn't mean people will be happy with the factory spring rates nor does it mean the factory shocks are good or bad. The only fundamental problem with the leaf spring is the high cost of the part.
have redefined my understanding of "Performance Suspension".
What is the "life span" of a monoleaf? Is there a danger, for fiberglass models, of it ever just cracking or breaking? Any actions that would reduce or increase longevity of the spring?
You've assumed that a sway bar is essential.
You've assumed that a sway bar has to work through the entire suspension travel.
You've assumed that a sway bar has the same resistance throughout it's travel.
If you take the two extremes, a car with no front sway bar and coil springs and a car with a monoleaf and no sway bar, the car on coils has truly independent suspension.
Take both cars onto a rough surface and the car on coil springs will massively out perform the mono spring because the wheels will be allowed to follow the contours of the road independently. The monoleaf by comparison will cause wheel skip and body pitch and roll as the two sides of the spring interact unevenly together.
I'm not saying the monoleaf doesn't offer a good compromise, working as sway bar and springs but it wouldn't be my idea of an 'upgrade'.
I actually made no claims about the sway bar resistance through its travel. I would actually assume that most swaybar systems (including what we see on the Corvette monoleaf) have a spring force that follows F=k*(difference between wheel positions). The force is linearly proportional to the difference in wheel positions. This would be the same spring rate but not the same force.
