power steering pump pulley
Old Feb 7, 2010 | 01:31 PM
sweeet76's Avatar
sweeet76
Default power steering pump pulley
I'm having trouble removing the pulley from the old power steering pump. Does anyone have any suggestions.
Thanks,
Bill
Old Feb 7, 2010 | 02:52 PM
BKarol's Avatar
BKarol
Might want to go to Auto Zone and have them loan-a-tool you a
"Powersteering Pump Pulley Puller" and see if that works.
Old Feb 7, 2010 | 03:13 PM
Jim Shea's Avatar
Jim Shea
Your 1976 Saginaw power steering pump has a interference fit pulley.
You must use the correct tool to remove the pulley. Otherwise you run the risk of bending the pulley and also damaging the parts inside your power steering pump. The special tool has a collar that will match the groove on the pulley hub. Also the tool will have a center bolt that will react against the pulley shaft and draw the pulley off of the shaft without putting stress on the pump.
There is also a correct tool in order to assemble the pulley to the pump shaft as well. You usually can borrow the tools from the major automotive stores for no (or a slight) fee.
Jim
Old Feb 7, 2010 | 10:39 PM
sweeet76's Avatar
sweeet76
Thanks everyone, I did borrow a puller from the auto parts store and it did the trick. Thanks again for taking the time to help.
Bill
To power steering pump pulley
