Engine Rebuild Questions....
Old Feb 7, 2010 | 03:15 PM
ShaneLU97's Avatar
ShaneLU97
Default Engine Rebuild Questions....
So I am in the midst of my winter projects including my engine rebuild. I have gotten a lot of great feedback thus far from my old posts:
http://forums.corvetteforum.com/c3-t...tion-long.html
I have a few follow-up questions based on some other posts I have read recently.
1) Do I need a wear plate such as this one from Jegs?
http://www.jegs.com/i/Comp+Cams/249/201/10002/-1
2) I have found some "true roller" timing chain set-ups on Jegs and Summit as well. Is this marketing or something I need to buy specifically for my build-up?
Shane
Old Feb 7, 2010 | 04:14 PM
Mastr Fab's Avatar
Mastr Fab
When installing a roller camshaft you need a method of controlling forward and aft movement of the camshaft.This is done in older blocks by the use of a cam button that is shimmed to limit this movement by controlling the clearance between the cam button and the timing chain cover. Several timing chain sets have a torrington bearing or brass bushing that keeps the cam gear from wearing on the front face of the block. A roller chain is an improvement over a stock type chain. A true roller chain is better but IMO is partially a marketing ploy.
Old Feb 7, 2010 | 05:31 PM
ShaneLU97's Avatar
ShaneLU97
Bought the Cloyes cover with the button built-in but looks like I need to get a new timing set as well. Is a torrington bearing the same as the thrust bearing?
Would something like this be it?
http://www.summitracing.com/parts/LUN-93113/?rtype=10
Old Feb 7, 2010 | 08:01 PM
ShaneLU97's Avatar
ShaneLU97
OK. Here is the one I think I am going to order. Any opinions? Will this work on a 73 now going to roller cam, etc?
http://www.summitracing.com/parts.aspx?sku=SUM-G6600-B
Old Feb 7, 2010 | 10:38 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
That will work, here's the one I got for my 427ci, it has an encapsulated torrington bearing to prevent block wear
http://www.summitracing.com/parts/CL...0TX9/?rtype=10
Old Feb 7, 2010 | 10:42 PM
ShaneLU97's Avatar
ShaneLU97
Thanks. After looking a little more, I ordered this one instead.
http://www.summitracing.com/parts/SUM-G6605-B/
Old Feb 7, 2010 | 11:23 PM
MotorHead's Avatar
MotorHead
Has your block been line bored ? That particular timing set is .005" reduced chain length to compensate for a line bored ( don't get confused with honed) block, you won't get it on. Better see if you can change it to a normal one if your block hasn't been line bored.
Old Feb 8, 2010 | 07:28 AM
ShaneLU97's Avatar
ShaneLU97
Will call this AM and cancel that order. Both of these would appear to work as well although I am not exactly sure why one is twice the price of the other:
http://www.summitracing.com/parts/SUM-G6600-BA/
http://www.summitracing.com/parts/SUM-G6600-B/
EDIT - Upon closer inspection of the pics, the more expensive one has adjustments to allow for timing adjustments on the cam wheel.
So would the other one be ok? This is my first engine rebuild and I am paranoid it is going to blow up in my face.
Shane
Old Feb 8, 2010 | 11:24 AM
jimvette999's Avatar
jimvette999
If you go with the Cloyes w/Torrington bearing, the black side of the bearing goes against the gear. That tid-bit is not included in their instructions. I had to call Cloyes to find out.
Jim
Old Feb 8, 2010 | 11:31 AM
Mastr Fab's Avatar
Mastr Fab
That's explained in step 5 of my cloyes instruction sheet.
To Engine Rebuild Questions....
