Bored Block .060 over!
Old Mar 7, 2002 | 01:42 PM
Steve Adkins's Avatar
Steve Adkins
Default Bored Block .060 over!
Just found out that the machine shop had to bore my block .060 over. Is that something that is normal or am I going to have problems with it over heating etc...? I have a 350/350 #'s matching that is at the maching shop. I am having the works done to it. Maybe I am just paranoid, but I worry about everything. I was expecting about .030 over. Can someone give me some knowledge on this? :crazy:
Thanks,
Steve
Old Mar 7, 2002 | 02:19 PM
gkull's Avatar
gkull
Default Re: Bored Block .060 over! (Steve Adkins)
Over the years I have ran two 60 over without a problem. They only got that way because the previous bore of 4.030 was so out of round that they don't clean up at .040 over so they have to go .060. It's not a big deal in 4 bolt 397010 blocks because they are stronger. On my race engine I had it sonic tested for thickness. It checked out OK but I half filled the water jackets with epoxy for additional strength.
Just have a good balance job done and run a combo of distilled water/anti freeze and never give it another thought. My old 336 tunnel ram motor has been running for 15 years with a .060 over in a street rod 53 tubbed pickup.
[Modified by gkull, 8:08 PM 3/7/2002]
Old Mar 7, 2002 | 03:22 PM
Corey_68's Avatar
Corey_68
Default Re: Bored Block .060 over! (gkull)
.060 over bore is VERY common, you will not have any problems over heating, plus you'll pick up a couple cubis inches plus more hp and tq. :yesnod:
Old Mar 7, 2002 | 05:05 PM
73Ken73's Avatar
73Ken73
Default Re: Bored Block .060 over! (Thad)
My block is .060 over and I have had no problems. The machine shop said my block is a 010 block which has a high nickle content and makes it a strong block.
Old Mar 7, 2002 | 05:32 PM
Steve Adkins
Default Re: Bored Block .060 over! (73Ken73)
Thanks guys, the machinist told me the same thing. He said that he bored them 60 over every day. It's good to get reassurance from you vette pros! :cheers:
Old Mar 7, 2002 | 08:41 PM
Nomad78SA's Avatar
Nomad78SA
Steve,
Are you going to stroke it while you are in the motor?
Neil in Tenn
Old Mar 7, 2002 | 09:48 PM
Steve Adkins
Default Re: Bored Block .060 over! (Nomad78SA)
Neil, I thought about it, but decided not to. My engine is pretty strong the way it was. I figure by the time I get done with it, it will be a little stronger. :yesnod:
To Bored Block .060 over!
