Stock Intake Manifolds - BB
Old Feb 20, 2010 | 08:45 PM
Irish69427's Avatar
Irish69427
Originally Posted by bigvette1
Hi Irish,
What tri power setup did you use? So a tripower manifold and the 3 2's fit fine under a C3 hood with a BB. Would you be able to post or sent out a pic of the setup? Thanks.
PS -
My motor is going in now and should be done this week. I will post some pics then. The key is you must use a 68 or 69 tripower manifold. The 67 version will not fit under a 68-72 BB hoodline. The 68-69 design is lower and I thought it would give up some horsepower to the earlier 67 high rise version but the dyno said otherwise. It works really good and you are running of the center 2 barrel unless you mash it so economy is great.
Old Feb 20, 2010 | 08:48 PM
eagle275's Avatar
eagle275
Default ....
