Edelbrock 60739 heads
Old Feb 9, 2010 | 10:16 PM
mr303's Avatar
mr303
Default Edelbrock 60739 heads
Just bought a pair of these today, they are the 70cc version of the performer rpm range heads. I studied the flow bench figures supplied by Edelbrock and noticed that they flow better than the 64cc version. I am guessing that they have less valve shrouding by having a larger combustion chamber? Does anybody have these heads? At the price they were offered I could not refuse, they are brand new fully assembled ones.
Thanks in advance. Glenn
Old Feb 10, 2010 | 12:08 AM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
Not a bad set of heads. Should work well on a 350-383 size engine. Certainly there's better, but there's always something bigger/better. These would support ~500 hp if that is your goal.
Your guess about the flow vs. CC volume is likely correct - unshrouded valves.
Old Feb 10, 2010 | 02:02 PM
mr303's Avatar
mr303
No doubt there are better heads around but the price of these makes them very attractive and they are US made and assembled so I can trust the quality. I was thinking of running a +3.5 cc Probe dome piston which will bring the comp ratio up to where I want it.
Old Feb 10, 2010 | 03:43 PM
c31980's Avatar
c31980
ya they will post your comp with those heads ,,, & a good cam
good luck
Old Feb 10, 2010 | 04:29 PM
mr303's Avatar
mr303
I have a Isky 270 mega cam to put in it, fairly short duration with a .465 lift. I am wanting a engine that will pull form 1500/2000 rpm, I'm not really a big rpm spinner so if it tops out at 5000 that's fine by me. the Edelbrock heads with 185cc runners should give a good low rpm response and retain a decent idle vacuum.
To Edelbrock 60739 heads
