Big bog with holley double pumper
Old Feb 9, 2010 | 11:10 PM
dragon69's Avatar
dragon69
Default Big bog with holley double pumper
Hi all,
Just put a slightly used but stock Holley 650 double pumper (4165) on my semi stock Vette. It runs great until I open the secondaries, there is a very bad bog. Tried to adust air/fuel mixture and ignition timing but didn't fix the problem.
Is there something I'm missing to do, did it happen to anyone else?
Ken
Old Feb 9, 2010 | 11:54 PM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
Originally Posted by dragon69
Hi all,
Ken
First off - tear it down and verify/set it up to original Holley specs using HOLLEY parts. Jets, Accel pumps, PV, Accel pump nozzles, cams, etc. Next, verify the float levels are correct on the warmed up engine. Set Idle mixture & rpm. Report back once this is done & we can take it from there.
Old Feb 10, 2010 | 04:19 AM
baxsom's Avatar
baxsom
auto or manual?
Old Feb 10, 2010 | 07:43 AM
bashcraft's Avatar
bashcraft
Sounds like the accelerator pump for the secondaries isn't working. It's easy enough to check.
Old Feb 10, 2010 | 08:06 AM
73StreetRace's Avatar
73StreetRace
First, what is your timing ?
Then, as Ben Lurkin said, tear the carb down and verify/set it up to original Holley specs using HOLLEY parts.
Assuming your timing is correctly set, and that all the carb parts are identical to your holley carb list, check and adjust accelerator pump cams.
Remember that pump response must be instantaneous to the movement of the throttle. Holley web site shows the correct procedure for adjustment. ( Videos and .pdf files ).
If it backfires or hesitates, then goes, try bigger cams and /or bigger discharge nozzles.
First try a cam that will activate the pump sooner, like a red / orange / green one.
If it's not enough, then try #0.035 discharge nozzles. Once you get a small puff of black smoke when you floor the gas pedal,
then you have done enough ! Double pumpers like a big initial shot.
This procedure is much easier and accurate when you own a wideband AFR meter...
Old Feb 10, 2010 | 09:09 AM
thegazman's Avatar
thegazman
Default thegazman
Sounds like you are getting a lot of air without adequate fuel. Check accelerator pump.
Old Feb 10, 2010 | 02:09 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Originally Posted by baxsom
auto or manual?
Very important question, that. IME mild SB's with auto transmission aren't typically at their happiest with mech 2nds.
Also, as mentioned by others, at first thought this sounds like insufficient fuel delivery upon opening the 2nd bores. That said, I wouldn't do any adjusting to the carb until you know the ignition system and timing are dead on.
Old Feb 10, 2010 | 02:28 PM
gerry72's Avatar
gerry72
That assumes he's going lean upon throttle application. This is usually accompanied by a lean backfire. He may want to investigate a rich bog. This carb has a 50cc secondary pump so I doubt it is a lean issue unless there's a pump problem and he's getting a backfire.
Old Feb 10, 2010 | 02:46 PM
bashcraft's Avatar
bashcraft
If I'm not mistaken, a 650 should have a 30cc pump, primary and secondary.
Old Feb 10, 2010 | 03:16 PM
gerry72's Avatar
gerry72
You are mistaken. A 4165 has a 50cc secondary.
To Big bog with holley double pumper
