help hooking up a street fire ignition.
Old Feb 10, 2010 | 08:56 PM
airtime's Avatar
airtime
Default help hooking up a street fire ignition.
i traded for a new msd street fire ignition. new in box with a installation diagram on rear of box. anyone hooked one up with an hei before? my hei has one power wire and that's it. i see the full time hot wire and ground for the box. i guess the ignition wire is self explanatory.. i guess what has me confused is the orange wire (positive on coil) and black wire (negitive on coil). my coil is built in on my hei? do i have to splice into the under cap connections? not looking for performance gains with this thing, just wanted the rev limiter and the multi spark for starting and cruising benifits.
thanks
gerald
Old Feb 10, 2010 | 11:08 PM
airtime's Avatar
airtime
bump
Old Feb 11, 2010 | 12:05 AM
DRIVESHAFT's Avatar
DRIVESHAFT
Did you get the instructions in the box?
If not, here is a link to the instructions (if I guessed at the right box)
http://static.summitracing.com/globa...0_frm28899.pdf
HEI info is on page 5
Old Feb 11, 2010 | 09:58 AM
airtime's Avatar
airtime
looks like i have to replace the module with the by pass harness.
thanks for the info. no instructions in box just the diagram on back.
To help hooking up a street fire ignition.
