Do poly motor mounts make engine sit higher than stock mounts???
Old Mar 7, 2002 | 06:29 PM
James's Avatar
James
Default Do poly motor mounts make engine sit higher than stock mounts???
Just curious about you guys that are using Energy Suspensions or similar Poly Motor mounts.
Do they make you motor sit higher in the engine compartment than the factory style mounts?
Let me take it one more step farther are any of you that are using them running Hooker side pipes and big block?
Just trying to do a little research.
:rolleyes: :rolleyes: :rolleyes: :rolleyes:
