Picked Up Engine From Machine Shop
Old Mar 7, 2002 | 08:01 PM
ddn's Avatar
ddn
Default Picked Up Engine From Machine Shop
Picked up my toys today. Everything looks great, not that you could see anything wrong anyway. Just got a couple questions.
I didn't have them pressure wash, just degreased the heads and block. There's still some ugly orange paint on it. What's the best way to clean this off to shoot it with new paint?
For painting...is it best to assemble the engine, and then paint, or paint the bare block and bare heads before you do anything with them?
Anyone near southeastern Minnesota want to loan me some engine building tools :)
Old Mar 7, 2002 | 08:06 PM
Scott78's Avatar
Scott78
Default Re: Picked Up Engine From Machine Shop (ddn)
What kind of tools you need? Micrometers, engine lift, ridge reamer I have most everything to rebuild small blocks. The question is are you trustworthy :lol:
Scott
Old Mar 7, 2002 | 08:38 PM
ddn's Avatar
ddn
Farmington, wow, didnt think there were many people close. I think I'm gonna borrow some mics from the school shop, but they might not have the sizes I need..assuming they aren't wildly out of calibration too.
What I need right now is a valve spring compressor and soon a ring compressor. Just don't want to have to buy expensive tools to do a job once.
I think I'd be afraid to NOT be trustworthy with the vigilantes we've got on the Forum!
Old Mar 7, 2002 | 08:46 PM
Scott78's Avatar
Scott78
I've got both ring and valve spring compressor, neither are to fancy. And as far as I know I shouldn't need either for a few more months when I start putting another motor together. E-mail me and will work out how you can get them. sfrykh@frontiernet.net
Scott
Old Mar 7, 2002 | 09:31 PM
bence13_33's Avatar
bence13_33
David:
I'm not sure if lacquer thinner will work or not but it's worth a shot. Other than that I think a paint scraper or wire brush and some elbow grease will remove whatever paint is still on the engine.
With my 454 I plan on assembling the engine and then painting it. I do have some items that I painted seperately but assembling the engine and then painting will take much less time and will be a lot easier.
Old Mar 8, 2002 | 01:14 AM
JerryM's Avatar
JerryM
Carb cleaner usually does a good job at removing paint, etc.
The block should be thoroughly washed out completely inside and out including oil galleries with hot soapy water and BLOWN OUT WITH COMPRESSED AIR, then wipe down all machined surfaces with light oil before installing cam bearings, freeze plugs, oil gallery plugs etc.
The problem with painting after assembly is you invariably will spill/drip oil assembly lube, etc while assembling, then paint won't stick.
Just my $.02.
:chevy
Old Mar 8, 2002 | 01:33 AM
bence13_33's Avatar
bence13_33
Default Re: Picked Up Engine From Machine Shop (JerryM)
Jerry:
Wipe the block down real good with lacquer thinner before you paint and it should stick just fine :). The sucky part is masking off everything. I've found that aluminum foil works on most things you don't want to get painted. Mike also suggested putting vasoline on the freeze plugs (if you have pretty brass ones like I do and don't want to paint over them).
Old Mar 8, 2002 | 02:24 AM
Steve Straus's Avatar
Steve Straus
Default Re: Picked Up Engine From Machine Shop (bence13_33)
What's wrong with orange? :)
My new 468 is coming Chevy Orange. The ONLY color a chevy should be painted :D :D :D :yesnod: :yesnod:
Old Mar 8, 2002 | 12:36 PM
ylose's Avatar
ylose
Default Re: Picked Up Engine From Machine Shop (Steve Straus)
blue baby....paint the engine blue .....thats the chevy engine color of '78... :D
i wonder if the engine builders were color blind like me....and just walked in and starting painting with whatever they had....hence the color changes over the years... :lol: :lol:
To Picked Up Engine From Machine Shop
