telescope tilt 68
Old Feb 13, 2010 | 03:07 PM
base1957's Avatar
base1957
Default telescope tilt 68
There is a steel shaft that goes down the center of the column for the star bolt which is screwed into the shaft tightens against. Any one know the length and diameter of that rod.
thanks
Old Feb 13, 2010 | 05:55 PM
Jim Shea's Avatar
Jim Shea
I don't have a drawing of the rod. But my assembly drawings indicate that it should be very close to 13.6 inches. Both the 1967 locking rod and the 1968 locking rod are the same.
Maybe someone with a 1967 or 68 telescoping column can pull their rod out of the column shaft with a magnet and actually measure one.
The diameter would be 0.25 inch.
Jim
