Timing, dead cylinders...engine issues....
So here is the long version...
I got a killer deal on my 69 so I wasn't too concerned about the 350 engine which was said to run with a slight miss, I thought it was just groggy from not being driven and I could get her purring...not the case...
I contacted the owner before the fellow I got the car from and he informed me that he bought the car in the early 80's with a blower and that was said to be a fresh engine.
The engine was worn out so he had it rebuilt for the blower, he said he couldn't afford insurance with a blower so he took the blower off and had a stock intake installed but then the car was no fun to drive and basically saw in his garage since the early mid 80's.
His guess is the car didn't get driven 10K miles in that time and the fellow I got it from didn't drive it more that around the block and he said it had a miss.
So I decided to try to get some use out of the engine, I install a new HEI/Wires and a new Edelbrock carb, the first thing I noticed it how ragged it runs and that it doesn't like the timing set less than about 16 degrees before TDC which seems a bit much to me.
The other issue is three cylinders on the passenger side are dead, they are getting spark, but hey don't fire at all and the pipes stay warm...never get hot.
might be one reason why it runs so ragged...
Being this engine was built to have a blower I am guessing it is going to have some silly cam and low compression to be a good driver without the blower anyway but what do you guess would be the dead cylinders....valves...lifters....bad cam lobes?
I did plan to eventually install a BB in this project but did want to get some use out of the 350 that is in there,
I am in Orlando Fl,
Anyone got a good running engine for sale.....
you should have about ~.4" of spring compression.
Also, if you can get an old set of tin valve covers chop the top off and it becomes a great tool for doing things like this and more...
And do a leak down, it is way better than a compression check.... tells a lot more of a story
http://www.carcraft.com/techarticles...er/index1.html
I plan to do some testing tomorrow, starting with taking the valve cover off to see what those valves are doing...if they move then I will do the compression check,
My hope is something is just all hung up from the car sitting
I did the check on the valves and they all moved so I checked the compression and it was pretty much dead on three cylinders with just over 20.
So I look around on the net and engines are expensive...yep...grease rat was right "Speeds just a question of money ...how fast do you wanna go"
I call the outfit that built me an engine back in the 80's for one of my 81's the engine was a beast, I figure no way I can afford them now...
The fellow on the phone tells me he will build me a 350/350 for 2500.00
http://www.nationalcylinderhead.com/
So I ask....No, I mean you pull, you rebuild, you install...how much and he replies 2500.00 with a warranty.
So this day ended pretty cool...I feel even if my engine had ran, like someone else said it would have been a pig running without it's blower....
