10:1 ratio
Old Feb 18, 2010 | 12:43 PM
hicswa's Avatar
hicswa
Default 10:1 ratio
Can a 10:1 ratio be achieved with a 1975 L48 engine without changing the heads.
Danny
Old Feb 18, 2010 | 12:53 PM
Stu's81's Avatar
Stu's81
Change the pistons? Don't know if you could shave the heads that much.
Old Feb 18, 2010 | 01:03 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Flat top pistons and steel shim head gasket will get you close, but you still have L48 heads
Old Feb 18, 2010 | 02:32 PM
gerry72's Avatar
gerry72
Only by a piston swap. If you were to measure everything the actual static ratio comes closer to 8:1 instead of the 8.5. You would have to angle mill the head (really not something you should consider) and deck the block using the stock parts to get close to 10:1.
Old Feb 18, 2010 | 02:36 PM
Fast81's Avatar
Fast81
With iron heads you'd also risk "pinging" at that CR without CAREFUL timing adjustment and that is with hi-octane SuperUNL gas....may even need to run some Octane boost just to be safe.
To 10:1 ratio
