A/C Problems
Old Feb 18, 2010 | 02:52 PM
Harveyyachts's Avatar
Harveyyachts
Default A/C Problems
I have a 1980 L48 and everything works on the A/C, but all of a sudden the A/C won't blow through the vents. It only blows from the lower vent where the heater blows from. What could have gone wrong?
Thanks Kevin
Old Feb 18, 2010 | 03:07 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Thanks Kevin
Check the vacuum signal under the dash and at the switch.
Old Feb 18, 2010 | 03:12 PM
Harveyyachts
I looked at the console panel but not sure how to remove it without damaging it. I only found four screws and they are are the shifter. I removed them but still no movement.
Old Feb 18, 2010 | 04:18 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Two more screws at the front of the console beneath the stereo.
Ganey's Avatar
Ganey
I wrote this up awhile back for this problem.
The problem is that heater is the default position (no vac. or vac. leak) due to being designed in the north. Vent should be default. Very safe bet the problem is 1 OR 2:
1) The vac. line from engine may be damaged from heat - a small plastic tube that goes in below the hood alarm switch into wiper valley. Replacing most of engine side w/ hose will fix. OR
2) The vac. switch itself is not switching due to vac. leak as the usually plastic rivet is not holding the 2 main switch parts together well. Besides replacing, it is also possible to tighten this &/or lube w/ a thin layer of white lithium grease to fix.
3) If you have a heater, the small vac. tube to heater hose valve underhood may be damaged from heat & need replacing. Block w/o heater.
PS The design problem comment is not intended to be offensive to any of our northern friends.
Try pressing the 2 halves of the switch together.
Old Feb 18, 2010 | 04:33 PM
Harveyyachts
I found three small vacuum lines coming from the engine compartment going through the fire wall. They are colored white/green/black they all look to be in very good condition. Which one is for the A/C? Thanks Kevin
Old Feb 18, 2010 | 04:42 PM
Ganey's Avatar
Ganey
The source should be a small black plastic tube. From engine goes in below the hood alarm switch pass. side of dist. into wiper valley.
Old Feb 18, 2010 | 04:53 PM
Harveyyachts
The one that goes through the wiper valley is green and it runs down the passenger side.
Old Feb 18, 2010 | 05:10 PM
Ganey's Avatar
Ganey
It could have been replaced- look for the one I mentioned- it went to the engine intake vac. source.
Old Feb 18, 2010 | 05:33 PM
Mashman's Avatar
Mashman
The vacuum line that goes into the wiper valley, goes to the plenum door - this door opens to let fresh air into the plenum when on 'Max AC' - I don't think this is your problem.
Your problem appears to be the diverter that controls where the air, either hot or cold goes.
The diverter has 4 vacuum lines from the console control going to it - Tan and Pink control going to the upper vents, and Blue and Red control going to the lower. Follow these lines to the diverter, and make sure they are correctly connected
Also, you might want to take off the passenger dash pad, and move the H/C wheel back and forth and watch the cable that from the control panel, and see if it's moving the temp control.
Matt
Old Feb 18, 2010 | 05:40 PM
Harveyyachts
The hose you are speaking about, is it a thin hard plastic hose or the normal rubber hose?
Old Feb 18, 2010 | 05:42 PM
Ganey's Avatar
Ganey
"thin hard plastic hose"
Old Feb 18, 2010 | 06:08 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
You can access the AC vac lines at the controller by removing just the carpeted pass side console panel on 77-82.
Old Feb 18, 2010 | 08:57 PM
markdtn's Avatar
markdtn
I especially vote for #2, switch has come apart.
Old Feb 19, 2010 | 11:33 AM
Harveyyachts
Where can I get a replacement hose? What hold the carpeted panel on. I do not not see any screws. Thanks Kevin
Old Feb 19, 2010 | 01:34 PM
KapsSA's Avatar
KapsSA
3 screws. They're buried in the carpet, gotta look close. One on each end, one along side the seat. That's the hard one! 90degree screwdriver works to remove it.
Old Feb 19, 2010 | 03:06 PM
Harveyyachts
What switch are you speak about? The lever that switches from Max to Norm or one under the dash. If one of the lines are broke where can I get a new line or what would I use to splice them together. Thanks Kevin
To A/C Problems
Old Feb 19, 2010 | 03:53 PM
Harveyyachts
Old Feb 19, 2010 | 04:18 PM
Ganey's Avatar
Ganey
The switch is in the console attached directly to the selector for Vent/(A/C)/Heat/Defog.
I just remove the 1 front screw from a side console panel for access.
A piece of hose works great to replace part of a tube.
Old Feb 20, 2010 | 06:01 PM
Harveyyachts
My problem was the switch. The clip was broken. Where can I get a clip or a new switch? Thanks for your help. Kevin
