Apache running too rich
Old Feb 18, 2010 | 06:49 PM
chevyfiftynine's Avatar
chevyfiftynine
Default Apache running too rich
I've got a '69 Corvette 350 but it's my Chevy Apache pick-up that's giving me problems. I haven't been able to find a good Apache forum, so I thought I'd try the Vette owners for advice. It's a 58, straight six 235, column change, but it's running far too rich. It has had two non-original Rochesters fitted but it won't start if I turn down the mixture. The plugs are always sooty and the consumption's far too high. If anyone can offer any advice or suggest another forum I'd be grateful.
Regards,
Barry.
Old Feb 18, 2010 | 06:54 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Here's a good truck forum.
http://www.stovebolt.com/ubbthreads/...s.php?ubb=cfrm
I've got a '58 as well. Can't help you with the 6 though. I'm running a 350.
Old Feb 19, 2010 | 09:59 AM
EC_BG124's Avatar
EC_BG124
Sounds like too much choke, or float set too high (flooding), but I always had good luck finding answers here:
http://67-72chevytrucks.com/vboard/f...splay.php?f=13
It says 67-72, but they have a bunch of forums. The link above is to the 47-59 forum. Good luck.
Old Feb 19, 2010 | 10:36 AM
hugie82's Avatar
hugie82
I had a nova with the 2 carbs and I would say you have an intake manifold leak. Thats why it won't run when you try too lean it out.
Spray some WD40 around the gasket areas and try not to light yourself on fire. LOL
Old Mar 6, 2010 | 09:51 AM
chevyfiftynine
Default Stovebolt forum
Thanks for info on Stovebolt forum which I have contacted - and thanks for pictures of Apache. It looks great, much better than the condition of mine. Useful photos to help with restoration.
Old Mar 6, 2010 | 09:59 AM
chevyfiftynine
Default Chevy Trucks
Thanks for info on Chevy Trucks. Hopefully I'll get the carb problem sorted. They need to know referrer before I can join. Can you tell me your user name for this forum please? You can e-mail me directly if you like - barry.pringle@virgin.net
Regards
Barry.
Old Mar 6, 2010 | 10:02 AM
chevyfiftynine
Default Intake leak
Thanks for your theory of possible air leak in manifold. I'll try your suggestion with WD40. Regards.
L88Plus's Avatar
L88Plus
Might find some help here, too. They have several forums, this is the '47 - '59:
To Apache running too rich
