speedo dash
Old Feb 19, 2010 | 12:27 PM
Sho'nuff's Avatar
Sho'nuff
Default speedo dash
ok, i took all the perimeter bolts out of dash but something is holding it from sliding forward so i can replace speedometer. WHAT???
Old Feb 19, 2010 | 12:58 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
Just a shot but is the cable undone from the back
Old Feb 19, 2010 | 01:18 PM
Sho'nuff's Avatar
Sho'nuff
nope, it has to be?
Old Feb 19, 2010 | 02:13 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Sho'nuff
nope, it has to be?
It won't move very far with the speedo cable attached. FWIW: did you drop the steering column?
Old Feb 19, 2010 | 02:21 PM
Sho'nuff's Avatar
Sho'nuff
Yes. will try again later. Looks like the air duct will need to come out to see the cable.
Old Feb 19, 2010 | 05:34 PM
oldsarge's Avatar
oldsarge
Depending on the year, did you remove the column cover, under column and the brackets crossing at col'n, they are all attached to the dash, one way or another.
Old Feb 19, 2010 | 08:11 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Sho,
You might want to take a look at this link.. There are some good pictures that will help you. http://willcoxcorvette.com/repairand...lp.php?hID=105
Step by Step instructions.
Willcox
To speedo dash
