Brake Lines
Old Feb 21, 2010 | 01:15 PM
jordan89's Avatar
jordan89
Default Brake Lines
I've been wondering, do you have to apply any Teflon tape or something on the brake lines so they won't leak?
Old Feb 21, 2010 | 01:38 PM
Duke94's Avatar
Duke94
No, the flare on the end of the tube does the sealing, not the threads on the nut.
Gary
Fuelie74's Avatar
Fuelie74
No. On flair connections the seal comes from the flair face not the threads.
Old Feb 21, 2010 | 01:43 PM
dannyman's Avatar
dannyman
No tape, it's a dry seal. Having said that; a drop of brake fluid on the ends and threads when connecting is common practice.
Dan
jordan89's Avatar
jordan89
Thanks. I thought I was gonna have to take things apart again.
Old Feb 21, 2010 | 01:44 PM
682XLR8's Avatar
682XLR8
No sealant anywhere on the brake system. Either copper washers at the calipers or flare fittings on the lines will seal without the need for any additional sealant
Old Feb 21, 2010 | 06:54 PM
Roco71's Avatar
Roco71
Speaking of brake lines I just changed ALL of mine this weekend. The front to rear was a real PIA. And by the way I did not use any sealer or tape of any kind.
Old Feb 22, 2010 | 09:14 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
Using Teflon tape is NOT recommended. Using it can allow the fittings to back out over time, which is a bad thing.
To Brake Lines
