Vacuum source for heater/ac controls.
I wondered if a leak on the heating side of things would affect the lights. In all the vac trouble shooting posts I have read, none mention checking the heating system.
Where would the vac source for the heating system be?
If it makes any difference, its on a 79 L82.
I know there is a damaged line ( ie cut off ) that goes to what appears to be the water diverter valve.
A/C Vent Heat vacuum source is a small black plastic tube that goes in below the hood alarm switch, pass. side of dist. into wiper valley.
If the vac. switch has a leak, the plastic rivet is usually not holding the 2 main switch parts together well. Besides replacing, it is also possible to tighten this &/or lube w/ a thin layer of white lithium grease to fix.
Block or fix cut off heater valve tube.
Gary
http://willcoxcorvette.com/instructi...ted_080509.pdf
Gary
Just searched my PC and found another willcox pdf showing the routing but not exactly where it connects to the source. Will have to double check mine tomorrow.
I have a similar problem, as my headlights come up then go down at engine startup, otherwise work normally.
The diagrams dont show WHERE the heater vacuum T's off the system. I removed mine with the Vintage Air, but dont recall where the heater system source vacuum came from (I know its from intake, but where does it branch off the main system??)
Rob
Im probably going to remove the air con from my car for 2 reasons.
1, Compressor is seized and so it isnt working
2, Here in the UK, Air con isnt a big issue! lol.
Also, the only time I use the blower is to demist the screen.
So, as Im not sure what components are actually installed and working in my system, is it possible to have it simply set to only blow from the dash vents? ie, if other parts/valves are missing under the dash, can I just hook it up for just that?
I guess I need to have a look to see exactly what is in place and what is missing.
Rob
