Please help! I was nearly complete with my brake rebuild and just finished fastening all the ventilating valves. Then I suddenly noticed that I had somehow probably fastened both rear outside calipers so much that the metal surrounding the valve screws had broken! I guess there's no way to repair those now, huh?
Is there anything to try before I decide to buy new stuff? And if I need to replace these calipers, do you recommend ordering perhaps all new brakes from Ecklers or this http://www.summitracing.com/parts/SSB-A109/ ?
Are you talking about the bleeder valves? You should be able to use an "easy out" to remove the broken ones if that is the case. They are tapered and screw in counter clockwise to try and brake the thread seat free.
Less than $5 repair, here they are from Sears:
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
its not clear to me if your were tightening the calipers to the spindles and broke the caliper casting or if you were tightening the bleeder valves and broke the casting, or if you just stripped the threads on the caliper for the bleeder valves, .....if you stripped the threads perhaps you can find larger bleeder valves and have the calipers machined to accept them. i see you are in Estonia i do not know the metric sizes of stuff or if you have machine shops like we do here in the states, perhaps there are metric sizes a little bit bigger. If it was the casting that broke i cant imagine breaking those like that. some body must have really torqued on those to do that. some guys are really heavy handed if you are one of them buy a torque wrench it will help in getting the feel for the proper tightening effort. i use to work with a guy on cars who was a pipe fitter damn if he didnt break everything he touched.....your real caliper choices are for either an O ring set up or a the original lip seal. good luck bob
If you could post some pictures that would be very helpful. I doubt that you could crack the caliper housing by over-tightening the bleeder screws, so it sounds like you may have broken some of the bleeder screws. If you spray penetrant on the threads and use screw extractors you should be able to get the bleeders out without causing any more damage.
If you decide to buy new calipers I's recommed the VB&P O-ring calipers. They should be less prone to leakage than the stock calipers, even with SS-steel linings.
I'll try to get some pictures for you... However, I DID break the caliper metal around the bleeder valve screw. I didn't even tighten it very strong and as soon as it began giving me some resistance I saw a crack appearing out of the new paint I put on the caliper. I removed the screw from there and a metal piece of the caliper surrounding the screw-in area came off. I don't know how such a thing could even happen...
I think the same. I think that new brake set order is to be carried out soon. Well, I gotta think positive - perhaps my "restored" brakes would have given me a lot of trouble during Summer driving season anyway.
I have seen the metal break away at the bleeder screw. There is not much you can do except get a new one.
I don't know about where you are, but around here, Autozone, Advance Auto, and O'reilley's carry the replacement calipers in stock. I had to go to 3 different ones to get calipers that had not been drilled out and re-taped to larger bleeder valves.
Yours are still good for a core.
My rebuilt calipers didn't last long on my 71. I ended up replacing the calipers. I think the rebuild kits I got were no good. They started leaking almost immediately. I won't waste my time on those kits again.
That caliper set is not made by Summit- like most vendors they buy them from somebody else, possibly Lone Star. I imagine the shipping charges to Estonia and core charges would be a bigger factor than saving a few dollars on initial purchase price.
Thanks Mike. The shipping seems to be pretty OK from Summit and they aren't reporting any core need so it seems to be like a new product with no core charge. Can somebody tell me this?
