1980 corvette headlight switch question
Old Feb 23, 2010 | 03:18 PM
Vettestein's Avatar
Vettestein
Default 1980 corvette headlight switch question
all the lights on the outside of the vehicle work when I pull out the headlight switch, but none of the dash lights or dome come on. how can I bypass the switch to find out if I need to replace it or something else.
Old Feb 23, 2010 | 03:57 PM
Mastr Fab's Avatar
Mastr Fab
You could run a hot jumper wire to the fuse box inst lamp fuse and test the lights there. Also you could pull the dome light and run a wire from one side to a ground or a 12v source, not sure if the circuit is completed by grounding the light or adding 12v.
Old Feb 23, 2010 | 08:46 PM
2box's Avatar
2box
Same thing happened to me, the dimmer part of the switch was toasted.. So new switch..Good luck...
Old Feb 24, 2010 | 08:51 AM
jdp6000's Avatar
jdp6000
This is the dimmer part at the front of the switch. If the retrostat coil breaks close to the end none of the dash lights will work. You can replace just that part but the labor to get the switch out is the same so replace the whole thing.
[IMG][/IMG]
Old Feb 24, 2010 | 07:20 PM
...Roger...'s Avatar
...Roger...
Originally Posted by Mastr Fab
You could run a hot jumper wire to the fuse box inst lamp fuse and test the lights there. Also you could pull the dome light and run a wire from one side to a GROUND
Grounding the white wire should turn the the dome on.
Old Dec 26, 2019 | 02:46 PM
Jodie Moore's Avatar
Jodie Moore
would this effect the tail lights ? mine don't come on when I turn the lights on.
To 1980 corvette headlight switch question
