replacing calipers, need help
Old Feb 23, 2010 | 07:09 PM
taz7nads's Avatar
taz7nads
Default replacing calipers, need help
I've got my new calipers, to replace the ones I took off years ago before I parked my '70 coupe. But, my aging memory fails me. I have two with single bleeder screws, and two with double bleeder screws. Which ones are for the front, and which ones go in back?
Also, I noticed that the pads all have a thin metallic plate on the back side of the pad, but four of them have small hook/clips on the top edge. I'm assuming these are for the inside or outside, versus front or back; does anyone know how they go?
thanks, Taz
Old Feb 23, 2010 | 07:17 PM
michalbugno2006's Avatar
michalbugno2006
1 bleeder front
2 bleeder back
Not sure about the pads. All I know is my front metallic pads did not have what you are describing.
Best Regards,
Michal
fugawi's Avatar
fugawi
two bleeders, rear calipers.
Old Feb 23, 2010 | 07:20 PM
jordan89's Avatar
jordan89
double bleeders in the rear, single in the front.
Old Feb 23, 2010 | 07:25 PM
mds3013's Avatar
mds3013
Single bleeders go to front with bleeders on top pointing to center of car. Double bleeders on back, bleeders pointing up. The pads with clips go on outside on each caliper. They are wear indicators that rub rotors when pads get worn making a squeaking noise. mds...
Old Feb 23, 2010 | 07:27 PM
moosie982's Avatar
moosie982
but the pads dont sound right, if I am not mistaken all the pads, front , rear, inner, outer, are identical . Good Luck, Peace,,,Moosie
OOOPPS forgot about the squealers.
Old Feb 23, 2010 | 10:05 PM
72LS1Vette's Avatar
72LS1Vette
Be aware that the 'bleeders' on the lower part of the rear calipers aren't really meant for bleeding brakes. The rear caliper halves are reversible so the lower hole on the caliper should have a plug in it rather than a bleeder. Most rebuilders stick a bleeder in the lower hole because it fits but don't use it for bleeding the rear brakes. Air rises so opening the lower bleeder fitting won't accomplish anything.
Rick B.
Old Feb 24, 2010 | 08:19 AM
taz7nads's Avatar
taz7nads
thanks guys, now all I need is some warm sunny weather and I'll be set. I looked at the calipers again (got 'em from Duntov) and the fronts have the single bleeder, while the back have two bleeders and the plug. Without going out and putting them in place to see, I'm betting the plug goes at the bottom, with the bleeders at the top, inside and outside. Thanks again!
Old Feb 24, 2010 | 08:54 AM
wcsinx's Avatar
wcsinx
Correct, sounds like he's got a couple squeal plates.
Pull those stupid things off.
Old Feb 24, 2010 | 09:04 AM
MrJlr's Avatar
MrJlr
On a side note.....buy a Motive power bleeder (or something similar)....just re-did my brakes last weekend.....bleeding them to a perfect firm pedal was soooooooooooooooo easy....I love that tool !
Old Feb 24, 2010 | 11:15 PM
taz7nads's Avatar
taz7nads
the Motive power bleeder you mentioned, does any of the vendors here sell it, or any recommendations or where to get it?
Old Feb 24, 2010 | 11:27 PM
72LS1Vette's Avatar
72LS1Vette
That's correct.
Rick B.
Old Feb 25, 2010 | 03:46 PM
71rdster's Avatar
71rdster
I's sunny and "warm" now. Most of the weekend should be nice as well.
To replacing calipers, need help
