Timing gear/harmonic balancer length
Old Feb 24, 2010 | 03:20 PM
76GlassY's Avatar
76GlassY
Default Timing gear/harmonic balancer length
Hey everyone. Replaced the stock timing set with a Cloyes Premium True Billet roller set #9-3600TX9 which fits under the stock timing cover. Put the harmonic damper back on and noticed it sitting pretty far out from the cover. Checked pully alignment with the power steering pump and it's way out, 1/4" maybe. I assumed (yeah, I know the saying) it had to do with the thicker crank sproket gear but was hoping, knowing the alternative, that the damper wasn't pressed onto the crank all the way, just maybe hitting the sproket woodruf key and stopping. Pulled the cover, re-installed the damper and it's all the way against the crank sproket. Anyone else run into this? Don't want to space all my pullys and parts to make up the difference. Can only think to check the difference between the OEM sproket gear thickness and the Cloyes gear and shave that amount off the back of the damper hub shaft. Oh yeah, 76 L-48. Thanks for your ideas.
Old Feb 24, 2010 | 03:47 PM
MelWff's Avatar
MelWff
call Cloyes at (479) 646-1662
Old Feb 24, 2010 | 04:03 PM
jdp6000's Avatar
jdp6000
I did mine about 6 months ago. You need to rent the tool that push's the balancer back on. Don't hammer it and don't use the big bolt thats normally on it to pull it in. You will snap the bolt in the crank.
Its a bit nerve racking even with the tool. What you need to do is take the balancer off again.Take a measurement using the wear marks on the crank shaft. Lube up the shaft a bit. Put the balancer back on and start cranking the nut on the tool. Its going to take a while. You will find once its almost all the way in the whole crank will start turning. You will have to hold the pully with one hand as you tighten. Or rig something up like wedging a large screw driver in on of the holes on the pulley so when you tighten it with the tool the screwdriver hits the cross fame. Be patient. it will evenutally seat.
Jim
Old Feb 24, 2010 | 04:18 PM
76GlassY's Avatar
76GlassY
Thanks guys. Called Cloyes tech line, left a message and am waiting for a call back. The balancer is definately on all the way (and I did use the install tool), flush up against the new crank timing gear sproket. Problem is the new double roller sproket is thicker than the original single chain sproket. That's what's keeping the balancer/damper from going onto the crank snout deep enough for its proper placement and it's definately the correct balancer, measured the hub length and it's the same as the old one.
Mastr Fab's Avatar
Mastr Fab
There should be about 1 1/8" from the front face of the balancer to the end of the crankshaft.
Old Feb 24, 2010 | 05:37 PM
76GlassY's Avatar
76GlassY
Seek and ye shall find... that I screwed up on this myself. Pulled the new crank sproket and compared it with the original. Same thickness so I re-installed the old one to see how far it from the front of the crank snout it was when installed and realized that the large socket I was using to press on the gear was bottoming out on the front of the crank before the gear was fully pressed on. What do they say about the right tool for the right job. Kind'a feelin' like a "tool" right now after seeing what I did. Again, thanks everyone for the input... boy do I appreciate this forum and all its members.
Old Feb 24, 2010 | 05:40 PM
76GlassY's Avatar
76GlassY
Thanks Mastr Fab.... I guess you can call me Mastr Bate after that bone-head move!!!!!
Old Feb 24, 2010 | 08:55 PM
68/70Vette's Avatar
68/70Vette
Jim
There was a lot of postings about harmonic balancer remover tools about a week ago. A lot of people, including me, bought the $104 remover tool from Summit. With this tool, you can remove the balancer and install it, without causing the crank to turn. I removed and reinstalled a BB 454 balancer.
The least expensive remover tools will cause you to prevent the crank from turning. I think the least expensive tools cost about $30 US (S&K). If you can easily jamb the crank from turning, you can save some money for sure. The Summit tool has a Torrington bearing which greatly reduces the torque required to remove/replace the balancer.
To Timing gear/harmonic balancer length
