Passenger Side Window
Old Feb 24, 2010 | 09:08 PM
Baldwin Brave #77's Avatar
Baldwin Brave #77
Default Passenger Side Window
On my 1978 Pace Car, several rivets fell out of the passenger side door. After I replaced the rivets the window on goes back up unless I pull the window motor towards me. I'm baffled because I put the rivet that goes through the motor in very firmly. Any advice to what keeps this window from going up?
Old Feb 24, 2010 | 09:51 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Baldwin,
You'll need a little bit more info on this. What rivets fell out, the regulator rivets? After you replaced these rivets the window won't go up unless you pull it towards you.. Which direct is that.. Are you sitting in the car pulling the top of the glass inward, or are you pulling the glass upwards.
There are several things that will keep the window from going up. We rebuild our own power window motors here and similar to the windshield wiper motors, many given to us as a core have nothing wrong with them.
The rollers on the regulator could be binding, frozen, or even have a flat spot worn on it, teeth on the regulator gear could be bad, teeth on the drive gear may be bad, motor plate gear bushing could be bad.
One thing that will really mess with power windows is the generic outer window felts too! The flap is to large and they will create a drag on the power window equipped cars. Most people have enough mustard to crank up the window with these installed on a non power window car.
An yes.. a weak motor could also be your problem. What makes a motor week... The biggest failure we see in the motors is the armature/brush corrosion and dried up grease inside.
There are other things that can cause the glass to bind up on the way up and I'm sure if you post more info others will respond..
Willcox
Old Feb 25, 2010 | 06:25 PM
Baldwin Brave #77
I had to replace one rivet in the regulator and one other in the window motor itself. It stops when the window is barely out and when I pull the motor towards me the window will undo and go up.
Old Feb 26, 2010 | 06:11 PM
Baldwin Brave #77
Bump
To Passenger Side Window
