brake bleeding sequence
Old Feb 26, 2010 | 09:26 AM
taz7nads's Avatar
taz7nads
Default brake bleeding sequence
I recently read a very informative post from Tom454 reference bleeding the brakes. In said post, he stated that it did not matter which caliper was bled first; the important thing was to bleed the fluid intake side first. But, later he talked about the proportioning valve messing up if only a front or rear was leaking (or open), and said you should bleed a front and a rear at the same time.
Since my '70 has one one bleeder in front and two in back, I plan on bleeding front and interior rear first, then bleeding the front again when I bleed the outside rear, in an effort to keep the proportioning valve from going off center. Am I on the right track?
Old Feb 26, 2010 | 09:32 AM
Grumpy 427's Avatar
Grumpy 427
If this is a new system. You need to start by bench bleeding the master cylinder first. make sure all the air is out of that. Install it back on the car, re-connect the lines. Then do the furthest away from the master which would be the passenger rear caliper. from there the drivers rear, then pass front and last drivers front. This is how i have always done it on any car etc never failed.
Old Feb 26, 2010 | 11:15 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
On the rear calipers, the inner halves must be bled before the outers.
The chassis service manual says:
Left rear inner
Left rear outer
Right rear inner
Right rear outer
right front
left front
Old Feb 26, 2010 | 11:59 AM
taz7nads's Avatar
taz7nads
it is a "new" system, as it has been sitting for a LONG time. I'm putting on new hoses, four calipers, and went ahead and replaced the m/c while I was at it. The m/c has been bench bled and reinstalled, the rear calipers went on yesterday, and now I'm waiting on another decent-weather day.
Old Feb 26, 2010 | 01:00 PM
larryg3's Avatar
larryg3
that is how i did mine and they worked fine.
Old Feb 26, 2010 | 01:29 PM
SteveG75's Avatar
SteveG75
Left rear inner
Left rear outer
Right rear inner
Right rear outer
right front
left front
Way I did mine.
I have used both the gravity method and a Motive Products pressure bleeder. I love the pressure bleeder. It is only 10 psi of pressure which is not going to move that pressure differential switch at all. Just do one bleeder at a time.
Old Feb 26, 2010 | 02:49 PM
Easy Mike's Avatar
Easy Mike
[QUOTE=SteveG75;1573238038...Motive Products pressure bleeder. I love the pressure bleeder....[/QUOTE]
Me too. It's the only way to fly.
To brake bleeding sequence
