Engine swap question
Old Feb 26, 2010 | 02:25 PM
AT-82Collectors's Avatar
AT-82Collectors
Default Engine swap question
I am almost ready to replace the engine in my 82. I have considered a rebuild but I am looking for more performance than what the original motor can do without major mods. I was hoping someone else has done this swap using:
http://paceperformance.com/index.asp...&ProdID=131297
and could let me know if any issues that came up. Any advice would be greatly appreciated.
Thanks,
Andy
Old Feb 26, 2010 | 03:06 PM
MN-Brent's Avatar
MN-Brent
Looks great.
Your stock 700R4 may suffer greatly behind that motor. Consider updateing that sooner or later.
You'll also need to get a torque converter lock up kit for your 700R4. B&M makes one that hooks inline to your speedo cable and lock the converter any higher than ~35MPH if my memory serves me correctly.
You'll also need to mod your fuel delivery set-up. The intank fuel pump will need a regulator that can turn down the fuel pressure to carb levels ~6-8PSI.
Youll probably want to update your exhaust, as your CFI motor factory shorty headers set-up will be too restrictive for the ZZ4. You could look for some block huggers and then have a local exhaust place mate up to your original 2.5 inch pipe set-up after that, or your could go long tube headers and true duals if your feelin' rich.
These are just off the top of the head.
B.
Old Feb 26, 2010 | 03:43 PM
AT-82Collectors
Thanks for the reply. I thought the ECM would become useless and was wondering about the torque converter lock up. The fuel pressure is something I had not though of. I think new headers and duals will work well. No use getting cheap at this point.
Andy
To Engine swap question
