Edelbrock airgap intake
Old Feb 27, 2010 | 11:24 AM
c3_dk's Avatar
c3_dk
Default Edelbrock airgap intake
Hi,
I have to buy a new alu intake.
I am thinking about Edelbrock 7501 or 2701 (or?)
The engien is a 350 11:1 (L46 engine from 69) with Brodix IK180, Roller lifters, Comp cam 12-433-8 and Rocker 1,6
What intake will be the best for me?
Old Feb 27, 2010 | 12:07 PM
Ganey's Avatar
Ganey
There needs to be at least about 3/4" clearance over the Holley vent tubes.
The PRM would be better however there is not enough clearance for a proper setup RPM under stock SB hood 68-72.
The LT-1/BB hood is really the minimum for the SB high rise intakes.
Which hood & carb.?
Old Feb 27, 2010 | 12:10 PM
c3_dk's Avatar
c3_dk
Which hood & carb.?
Std hood and Rochester carb.
So I will go 2701
Old Feb 27, 2010 | 12:14 PM
Ganey's Avatar
Ganey
So I will go 2701
2701 is for a square bore carb.- will not work w/ Q-J.
2601 Air Gap will.
Old Feb 27, 2010 | 12:20 PM
C3 Stroker's Avatar
C3 Stroker
Originally Posted by TheFinn
I'm in unknown waters with 68-72 hoods: would the high-rise manifold not fit with drop base filter?
Yes, it will fit with a drop base air filter. Some bases drop deeper than others, but a 2" tall air cleaner can be substituted if needed.
Old Feb 27, 2010 | 12:23 PM
Ganey's Avatar
Ganey
The LT-1 used a 2" dropbase for the LT-1/BB hood.
The Torker 5416 would work w/ Holley. (2500-6500)
Vic. Jr is similar height as RPM.
Old Feb 27, 2010 | 12:29 PM
Al Davis's Avatar
Al Davis
Default Intake
Would I be able to use the Air Gap Qjet intake on a Edelbrock RPM headed 383 425hp?
Old Feb 27, 2010 | 12:35 PM
c3_dk's Avatar
c3_dk
2601 Air Gap will.
JEGS:
Edelbrock 2601 SB-Chevy 262-400ci 1955-86
Designed for 1955-86 262-400 c.i.d. small-block Chevys, the Performer Air-Gap features the air-gap design for the ultimate street performance in the idle to 5500 rpm range. This design features an open air space that separates the runners from the hot engine oil resulting in a cooler, denser charge for more power. High-velocity runners deliver excellent throttle response throughout the power band. The great looks of the Performer Air-Gap along with the solid idle to 5500 rpm performance makes this an ideal choice for street rods and street machines. No provision for exhaust heated chokes or exhaust crossover. For spread-bore or square-bore carburetors without adapter. Will not fit under stock Corvette hood.
Old Feb 27, 2010 | 12:36 PM
Ganey's Avatar
Ganey
Yes w/ the 76-79 med. rise hood. Even the previous 2101 would work to over 425HP & over 400 w/ 350.
I have the RPM, tried a 2" flat base filter that was going on a 305 SS, too restrictive for my setup.
Old Feb 27, 2010 | 12:46 PM
C3 Stroker's Avatar
C3 Stroker
JEGS:
Edelbrock gives this warning assuming you are using all other stock components (3" tall air cleaner and stock base). Under those conditions, you won't have enough room. However, if you use a 2" tall air cleaner or different drop base, you will have about 1/4" to 1/2" of hood clearance.
Old Feb 27, 2010 | 12:56 PM
c3_dk's Avatar
c3_dk
Perfect and thanks
Ganey's Avatar
Ganey
68-72 std. hoods.
May not w/ stock air cleaner.
Many run the 2101 under 68-72 hoods. The 2601 & 2701 are about a 1/4" taller.
So a drop base would do it for 2601 & 2701 68-72 hoods.
Old Feb 27, 2010 | 01:12 PM
c3_dk's Avatar
c3_dk
68-72 std. hoods.
This forum is just a gold mine, thanks all....
Old Feb 28, 2010 | 08:18 AM
STODD's Avatar
STODD
I think it was Super Chevy a year or so ago tested a bunch of SB manifolds, amazing how the air gap dominated all but above 65k in HP and torque. Unless your running wide open all the time it is athe best choice, even with a super victor & killer heads. I have the Dart airgap on my 75, I had to run a 1/2 spacer to connect to the vacume under a 750 holly DP. I run an edlebrock low profile aircleaner with a 3" filter and it bumps the stock hood a touch(need new paint anyway) The dart airgap is slightly different than the airgap though, got it at a swap meet brand new, cool looking but I wish I had the edlebrock.
To Edelbrock airgap intake
