Stock 74 350 (J Code) need part identification
Old Mar 1, 2010 | 09:01 PM
Paul ADK's Avatar
Paul ADK
Default Stock 74 350 (J Code) need part identification
I have a strictly stock 1974 350 J code engine with no power steering, power brakes or air conditioning. The car does have all the original emissions control, AIR pipes, smog pump, you name it.
My problem is that on the right side of the intake manifold there is a small "canister" that has both electrical and vacuum functions that is rusted and I believe needs to be replaced. There is a two prong electrical connection and a single straight Metal vacuum connection on the base while the top or opposite end has a single plastic "T" for two vacuum hoses. Given the length of the electric wire, it appears that the integral bracket is designed to be attached beneath one of the intake manifold bolts. I have not found any part number on the canister or the bracket.
A) What is the part called?
B) What is it's function?
C) What are the three vacuum lines supposed to be attached to?
Any and all answers will be greatly appreciated.
Old Mar 2, 2010 | 08:04 AM
Paul L's Avatar
Paul L
Do a search on Transmission Controlled Spark (TCS) system. Is your car a four-speed?
Old Mar 2, 2010 | 08:38 AM
Paul ADK's Avatar
Paul ADK
Yes, the car is a four speed. If this is the Vacuum Advance Solenoid and I am correct, one hose goes to the distributer, and a second goes to the carburetor - what connects to the third outlet? Is it by any chance the air pump diverter valve?
Thanks again,
Old Mar 2, 2010 | 09:22 AM
Mike Ward's Avatar
Mike Ward
I've seen TCS solenoids on eBay every now and then.
Old Mar 2, 2010 | 10:59 AM
jotto's Avatar
jotto
Ebay, NOS,
http://cgi.ebay.com/ebaymotors/73-4-...Q5fAccessories
priced at $69.99 + $5.00 shipping! eek..is that a god/bad price???
http://cgi.ebay.com/ebaymotors/73-74...Q5fAccessories
$59.95 + $8.00 shipping.
Old Mar 2, 2010 | 04:11 PM
Paul L's Avatar
Paul L
Thanks again,
I must confess that I do not understand that system. So I just pulled it off and went with vacuum advance to manifold vacuum directly.
The four-speed and Th400 solenoids are different. My car is an automatic. The units referenced above seem to be for a four-speed.
As I understand (not well) with the TH400 one hose goes to the vacuum advance, one goes to manifold vacuum, and the third to ported vacuum. The electrical connection is to the thermal switch in the passenger side head between cylinders # 6 and 8. How this all comes together is a mystery to me. So I just gave up and removed it.
Much the same with the seat belt interlock system. Just gave up and it is gone.
Old Mar 2, 2010 | 04:17 PM
Mike Ward's Avatar
Mike Ward
The solenoid inhibits the intake vacuum signal from getting to the advance unit on the distributor except for select circumstances. I think the transmission must be in 3rd or 4th gear, and the motor full warmed up.
I don't remember there being three ports on the solenoid, only two.
Old Mar 2, 2010 | 04:57 PM
Paul L's Avatar
Paul L
Mike,
I have been poking about on this one during the day. The GM numbers for this (1973-74, 350cid) are 1997410 for the four-speed and 1997425 for the TH400. The former has two spouts and the latter three as per my pic and for the routes I have noted.
So the first EBay post above is correct for the manual transmission (and stated as such) and the second mis-labelled: it for an automatic. Note the three spouts.
This diagram shows the three ports. The TCS system is operating on both manifold and ported vacuum. That is where I became confused and just gave up.
Old Mar 2, 2010 | 05:44 PM
Mike Ward's Avatar
Mike Ward
Here's a diagram from Doc Rebuild that confirms the three hoses but is not clear as to where they each go
http://www.docrebuild.com/dr-r-web/3750355.HTML
Old Mar 2, 2010 | 07:06 PM
Paul L's Avatar
Paul L
Yes, I saw that in my research but it is not terribly clear. But it does look like there is both a manifold and ported link from that solenoid unit. For what purpose? And how it links to the transmission? I am sure the Ontario Smog Patrol can solve this for me next summer. They are the experts.
To Stock 74 350 (J Code) need part identification
