Drive line angle vibration???
Old Mar 1, 2010 | 11:18 PM
MGB's Avatar
MGB
St. Jude Donor '14
Default Drive line angle vibration???
Will hanging a degree reading protractor (magnetic) from the driveshaft with the car sitting on a level surface give the measurement I'm looking for? Shouldn't it be about 3 degrees? I'm getting a 1 degree reading. Thanks
Old Mar 1, 2010 | 11:38 PM
wcsinx's Avatar
wcsinx
no
You need to know the angle of the yokes coming out of the tranny and differential. You want them parallel, but not pointing directly at each other (as in, not making a single, straight line). I don't know if I'm making any sense. Here's a good writeup on driveline phasing.
http://jniolon.clubfte.com/driveline...nephasing.html
You'll find conflicting information on the angle necessary for C3's. IIRC when I redid my bushings, the Energy Suspension kit had me at around 2.5* without any shimming. I left it at that and haven't had any vibration issues.
Old Mar 2, 2010 | 04:55 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
This overly simplified illustration may help you visualize what you're after...
Old Mar 2, 2010 | 05:33 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Great pic Skunk. That pretty much sums it up about as good as I have seen it on here.
To Drive line angle vibration???
