Half shaft U-Joint failure-repeatly
Old Mar 2, 2010 | 01:03 AM
billlee's Avatar
billlee
Default Half shaft U-Joint failure-repeatly
What would cause a left outboard u-joint to fail in less than 1000 miles. I've had 2 fail so far in that time.
Could a twisted trailing arm cause this?
Old Mar 2, 2010 | 01:27 AM
Peterbuilt's Avatar
Peterbuilt
When the 'U' joints on the half shafts were changed did they use this tool?
If this was not used at least the half shafts should be bolted together so the flange does not get bent.
Old Mar 2, 2010 | 07:47 AM
JimT's Avatar
JimT
Sounds like you have a bent u-joint bracket, may be on the half shaft or the wheel. Also, be careful if you are lifting the rear of the car and spinning the wheels - too much of an angle for the joints.
Old Mar 2, 2010 | 09:15 AM
gkull's Avatar
gkull
I just did my rear end and u-joints. It is very easy to bend the flanges.
What happens is the u-joint cap holes are not perfectly aligned. This causes a binding on every rotation which eats up the needle bearings in the caps
Old Mar 2, 2010 | 10:24 AM
joewill's Avatar
joewill
this time when you replace the ujoint, also replace the halfshaft to spindle outer flange.. it is probably bent.. if it is, then fix it right, get a new one.. be careful not to bend the new one!
it is 56$ at Zip..
Old Mar 2, 2010 | 10:50 AM
wcsinx's Avatar
wcsinx
Not to come across like a bubba or anything, but it's not hard at all to resquare the flanges. Just get a straightedge, carpenter's square, and a long socket wrench extension. Wrap a rag around one end of the extension, then use it to tweak those holes until they're both square with the flange and the straightedge sits flat across them.
(now everyone flame away at me )
In the future, you can avoid bending the flanges when removing u-joints simply by cutting out the trunions. Once the trunions are out, an air chisel will pop out those caps like nothing.
Old Mar 2, 2010 | 12:55 PM
gkull's Avatar
gkull
When you reassemble the 1/2 shafts and U-Joints the simple test is:
Do they move in each joint direction with the same ease? If not you have bending induced binding. I have straightened them on a press.
You don't have to be 100% perfect. When you bolt the flanges on each end down it will tend to pull them straight if you are nearly perfect
Old Mar 2, 2010 | 05:58 PM
68/70Vette's Avatar
68/70Vette
What''s the pedigree of the u-joints? They could be Chinese junk.
I agree with the previous comments about a possibly warped flange.
I think the original u-joints were AC Delco. Obtain some made in the US from a vette vendor, call Van Steel, Muskegan Brake, Wilcox, etc. Tom's Differential is a source also.
The u-joints that DO NOT have a jerke lubrication fitting are stronger.
Also, in removing the previous j-joints, you may have warped the holes in the flange where the u-joint fits into. I'd think off axis binding will kill a u-joint quickly. Maybe time to start pricing new flanges.
Old Mar 2, 2010 | 07:07 PM
billlee's Avatar
billlee
thanks for the answers
I installed the new u-joints with a press and they were not binding but I will check the ears when I replace them this time. Son took the car through a ditch backward a while ago so I was wondering if the ta might have been twisted a bit at the arm and the shaft do not align perfectly. I really do not want to have to replace the arm again,,,,wasn't fun the first time.
just a piece of advice,,,DO NOT share your toys with a teenager...they break them
Old Mar 3, 2010 | 04:49 PM
gkull's Avatar
gkull
When my daughter was younger she would ask for the keys to my two hot rods. I just ask if she had $10K in the bank in case something happens. When I grew up my parents had a very simple rule. We don't call the insurance--- YOU PAY FOR IT!
I had some very expensive nights in high school.
Old Mar 8, 2010 | 11:17 PM
jimmygmartin's Avatar
jimmygmartin
I had this problem and tried everything I could think of. I finally figured if it was constantly breaking then something must be binding. Sure enough the rubber travel stop was broken on the side that kept giving out. When I hit the gears hard the back end would squat and the U-Joint would bind and break. I replaced the stop and now can burn out without guaranteed breakage.
To Half shaft U-Joint failure-repeatly
