I have a power steering leak that is driving me crazy. I have replace the pressue hose and I have replace the cylinder twice. It seems it is leaking from the cylinder. The first time I had the cylinder I had it done by professional. The second time I did it myself.
My question is this. I'm wandering if he hooked my hoses up correctly. Should the two hoses going to the cylinder be crossed or should the bottom hose on the cylinder go to the bottom on the control valve.
If I have the hoses backwards have I damaged the cylinder and now I need a third one.
You must get an Assembly Instruction Manual for your year Corvette. It has the drawings that show YOU exactly how the hoses go. As to damaging the ram, I don't know, but it's only a hydraulic cylinder so it receives pump pressure all the time that the engine is running. It couldn't care less which side gets the pressurised fluid, so I think it's unlikely that you have done any damage.
Hopefully someone local to you will chime in and give you more help.
I cant help you with your leak but I did accidently hook up the lines wrong and believe me when they were hooked up wrong in my case the steering wheel kept violently jerking left to right. When I did hook them up correctly my stering has been working normally for years so I dont think if you did hook up the hoses wrong that it did any damage.
After installation of the cylinder, DO NOT GREASE IT! Even if there is a grease fitting present - they are supposed to be install ready, and applying grease will blow out an internal seal.
Good Luck.
JIMT,
You are confusing the assist cylinder (ram) with the control valve that is hooked to the pitman arm. Both may have zerk fittings.
The fitting on the assist cylinder only communicates with the ball stud on the end of the cylinder. So you could damage the ball stud seal on that end of the cylinder, but you cannot hurt the cylinder itself.
You can damage the control valve internal seals if you overpressurize the ball stud cavity.
take your front LF tire off,turn your steering wheel all the way to the right.looking straight in at the control valve,the bootom tube on valve connects to the top port on the cylinder.the metal tubes are crossed at the control valve.you cannot damage the cyl. by hooking them up backwards.if you are sure the leak is at the cyl.and it has been rebuilt twice,maybe the rod is bent or check for a nick in the rod.if the rod is pitted or nicked,it will tear your new seals out very quickly.also check for a cracked or bad flare on your hose ends where they connect to the cylinder.iif you are not sure exactly where the leak is coming from,clean the area good.i use brake cleanner or starting fluid and blow it off with a air hose.this will dry the area good and clean.i found my leak at the control valvei rebuilt and good to go.good luck.
On my 1974 Vette, I Tolerated a leak for some time thinking it was a bad hose. When I recently pulled the engine, I also pulled the entire steering rack to better understand the leak. What I found surpised me. "A piece of dirt" preventing a good mating. Disconnect your fittings and LOOK VERY HARD at the mating surfaces. You may find a damaged fitting or just some FOD (foreign object).
