What causes the rear of some C3's to appear jacked up like they're on air shocks? Some have the fronts and rears raised, but I notice it mostly in the rear end. Could this be caused by the rear leaf spring? How can this be adjusted so that the body appears to sit with the right wheel well clearance over the tires? I'm looking to buy a '72 that has this problem.
Lowering the rear end is simple. The rear end is suspended from the rear lateral spring by two bolts. Longer bolts lowers the rear end.
Check with "us" on the C3 Forum if you have any other questions before you buy. You're off to a good start by asking this question.
Most likely they have bought a TRW style composite rear spring that has their rear end all jacked up. They may not fully understand what it takes to get it lower, such as get rid of the spring, or buy super long 10 inch bolts to get it in the neighborhood of a "normal" ride height.
It's a stock spring. I was under there when I checked all numbers on the car. The rear is date coded correctly and matches the tranny also. I'm wondering if maybe the bolts were changed, if the rear was removed to be serviced at some point. I thought about putting a couple of 50 lb. bags of sand inside the rear storage area to bring it down. Or raise the front up too and make it a 4x4.
the original 72 spring was discontinued a long time ago and was superceded by Chevy using the part numbers of later years that weighed more. If the spring was changed this would account for the higher ride height and you would not be able to tell the difference by just looking at it. Try using the 8" bolts to bring it back down so the half shafts are parallel to the ground when the car is sitting with a full tank of gas.
Some guys raise the rear by adj. the spring bolts which allows wider tires that stick out. Besides throwing off the weight distribution & traction, w/ enough power they can easily be spun at 70 mph for ex., not to mention destroying the paint.
The AIM (Assembly Instruction Manual) has body dimensions and drawings in the front of the book. They show that the bottom of the frame is about 8.1 to 8.2 inches above the ground. That
's a good starting point to investigate body height. Also you want the rear axle half shafts to be pretty close to parallel to the ground.
The early C3's had relatively thin aluminum washers between the frame and the body. If the aluminum washers were replaced with the rubber bushings used in later year C3's, the body will ride higher. The aluminum washers are replaced by owners who want to get rid of body flexing noise.
Almost all C3's still are being driven with 15 inch wheels. If someone has installed modern low profile tires, the overall wheel diameter is noticeably smaller than the wheel well opening, making it look like the body has been jacked up.
Check out the frame to ground dimesions. Also measure the top of the wheel well openings to ground and report back. You can compare your dimensions with other cars.
