Fuel system for zz502
Old Mar 3, 2010 | 10:59 AM
rbat's Avatar
rbat
Default Fuel system for zz502
I need an electric fuel pump/lines for a stock zz502. I am looking for drivability (street) not strip performance. What size do I need and which model/brand is quiet and reliable.
Old Mar 3, 2010 | 11:04 AM
SteveG75's Avatar
SteveG75
The new ZZ502's come with the boss for a mechanical fuel pump. Do you already have the motor or are you about to buy it? You may be better off waiting.
From the GMPP catalog:
Clutch linkage bosses are now drilled and tapped. When using cast-iron exhaust manifolds, lower head bolts may need to be replaced with bolts with shorter heads, for clearance
502 engines now have a mechanical fuel pump boss!
Old Mar 3, 2010 | 11:21 AM
midyearvette's Avatar
midyearvette
it's about time for this...that's why i bought the 454 ho back in 2000..then it was the only one available with the pump boss....
Old Mar 3, 2010 | 11:28 AM
rbat's Avatar
rbat
Default Fuel pump
I already have the motor
Old Mar 3, 2010 | 11:31 AM
Corey_68's Avatar
Corey_68
I'm using a holley "blue" for my built 468
http://www.speedwaymotors.com/Holley...ign=GoogleBase
To Fuel system for zz502
