81 question/problem
Old Mar 6, 2010 | 12:15 AM
8preSSon1's Avatar
8preSSon1
Cruising
Default 81 question/problem
ive got an 81 all stock rebuilt tranny well i went to new mexico and left the car here in texas i hop in it to goto work took 6-7 tries for it to fire up ran for maybe thirty seconds died again after about 15 minutes of dying and restarting it finally caught idle at 500 rpms before it idle'd around 800-1000 anyways i back the car out of the driveway give it gas and it dies anything over 1500 rpm it falls on its face huge drop it power and barely running so my question is this just a clogged catalytic converter or something else?
additional info
car sat for 17 years before i purchased it
odometer reads 22134
replaced cap and rotor 2k miles ago
new plugs
new wires
Old Mar 6, 2010 | 12:20 AM
gingerbreadman1977's Avatar
gingerbreadman1977
fuel filter blocked maybe
Old Mar 6, 2010 | 12:24 AM
8preSSon1's Avatar
8preSSon1
Cruising
yea i thought about that took the air cleaner off and checked to see if anything was up with the carburator seemed fine might help if my gauges worked hahaha
Old Mar 6, 2010 | 12:29 AM
thiatt's Avatar
thiatt
How long has that gas been in there? Goes bad in just a few months. Also the fuel filter is on the front of the carb at the end of the fuel line. It just unscrews, pull it out and clean it with carb cleaner or replace it don't forget to put the spring back in and if it is a one direction filter take care to put it in right.
Old Mar 6, 2010 | 12:34 AM
8preSSon1's Avatar
8preSSon1
Cruising
its a daily driver its had a quarter tank for the last four days i fill it up every two weeks so you guys are thinkin fuel filter??
Old Mar 6, 2010 | 12:41 AM
thiatt's Avatar
thiatt
That's my guess. Did it run fine before you left?
Old Mar 6, 2010 | 12:44 AM
8preSSon1's Avatar
8preSSon1
Cruising
yea ran just fine no problem at all i just hope its not the same thing that happen to my Z28 it acted the same way and the timing chain was jumping teeth i guess ill go out tommorow and have a look
Old Mar 7, 2010 | 11:53 PM
8preSSon1's Avatar
8preSSon1
Cruising
alright so i pulled my fuel filter off today held on by two clamps its a one way blasted it with carb cleaner seemed pretty clean clamped it back on it ran better but still a little sluggish and i somehow burnt a half tank of gas in a couple hours so im wondering if it could be misfiring i checked that also all my plug wire were fine no tears burns ect.. going to pull the plugs tommorow to see if any are fouled any other suggestions???
Old Mar 8, 2010 | 12:54 AM
gingerbreadman1977
from what you wrote it sounds like someone has put an inline filter on. rochy also has one at the carb and i would check it.... 2 hours for half a tank sounds good to me. i would be happy with that.
Old Mar 8, 2010 | 06:07 PM
Tim81's Avatar
Tim81
How does the car run when its in Park or Neutral? Can you get it to rev past 1500 rpm then? I agree with the other posters that it may be sometype of fuel delivery problem. Maybe the last time you filled the tank you got some bad gas...
Old Mar 8, 2010 | 06:21 PM
LannyL81's Avatar
LannyL81
Did you have some "friends" put something into your fuel tank?
Remove the O2 sensor and see if it runs better. If so, then cat is probably plugged. This will set an error and engine will run in open loop when you try this.
Old Mar 17, 2010 | 12:02 AM
8preSSon1's Avatar
8preSSon1
Cruising
clogged cat i dont have the money to replace it its a night and day difference between it on and off i dont have the money to have a pipe welded in its place so im running open y-pipe till then it has an angry intimadating growl now hahaha
To 81 question/problem
