Radiator Support Upper Brackets
If you're going to keep this support, take the measurements from the old one and apply them to the new. If you have a welder at home or a buddy who has one, it helps. Weld up all the old holes and drill new holes. Yes, this is time consuming and your time is worth something, but if you want the job done quickly, you'll have to re-fabricate this new support.
I too was blown away at how poorly this new support was constructed.
BTW, I did call the vendor, no response.
Good luck,
Dewey
However the lower brackets fit perfect. rad. dropped right into those. Its the uppers that dont quit seem to fit right. I might just make something custom up there. Possibly use part of the bracket that is suppose to be there and fabricate the bolt hole part somehow.
Pretty sad when you spend $300 plus on just the support then brackets and all the cushions and everything only to find out half the side holes dont line up, nevermind the brackets. Sigh!!!!
