Strange problem with TH400 kickdown
Old Mar 7, 2010 | 10:37 AM
fwillison's Avatar
fwillison
Default Strange problem with TH400 kickdown
Recently acquired a 68 327/300 with a TH400 automatic. Functions well except no kickdown. I thought the problem would be with the sliding switch at the pedal, BUT, after messing around with timing and distributor issues it just started working out of the blue. 2 to 1, even 3 to 1 downshifts were happening!
Then, I finished the tune up, with new cap/rotor/points and set final timing and .... no downshifts again! Weird.
So can anyone make sense of this?
Can anyone explain how the kickdown functions and all the components? It seems there is a vacuum contribution as well as the electric pedal switch.
Old Mar 7, 2010 | 11:12 AM
pacrimmat's Avatar
pacrimmat
your kickdown switch has a wire connecting it to the kickdown solenoid in the transmission. easy replacement.
Old Mar 7, 2010 | 11:19 AM
fwillison's Avatar
fwillison
yes that part I understand, thanks
but I think there is a vacuum control component as well, and this may be where my problem is
Old Mar 7, 2010 | 12:35 PM
TimAT's Avatar
TimAT
The only vacuum to a 400 controls upshift feeland timing, all the kickdown function is electric.
At WOT, the kickdown switch opens the solenoid and dumps 2nd or 3rd oil, (depending on what gear it was in when it opened), As speed increases line pressure rises and when it overcomes governor pressure, it shifts to the next gear.
Old Mar 7, 2010 | 01:39 PM
JimT's Avatar
JimT
The kickdown function is totally electric. There is a switch located on the gas pedal, that once depressed provides 12volts to the tranny. I just had to replace my kickdown solonoid - very simple, and had to adjust my gas pedal to activate the switch. Your solonoid is easy to check, just apply 12volts to the connector on the outside of the tranny and you should hear the solonoid operate. There are several threads on the forum that explain the gas pedal adjustment. Trace the wiring for your 12volt source - it may be a bad connection around the distributor.
Old Mar 8, 2010 | 09:17 PM
fwillison's Avatar
fwillison
so it is purely electric, and the vacuum connection on the other side of the tranny could not cause a kickdown malfunction?
Looking at that passenger side vacuum connection on my car shows a steel vacuum line that comes from the right side of the intake manifold down to the tranny. The steel line comes all the way even with the connector on the the tranny, and at that point a rubber hose makes the connection between the steel line and tranny, but that hose is on a tight bend. I thought maybe it could have been pinched.
To Strange problem with TH400 kickdown
