BB Harmonic Balancer issues and more......
Old Mar 7, 2010 | 05:28 PM
mydejavooo's Avatar
mydejavooo
Default BB Harmonic Balancer issues and more......
Sooooo.....I have removed the harmonic balancer from a running 454 that I have, so that I could repaint the block and replace the timing chain cover....but now I have run into a question. How do you know when the harmonic balancer is on all the way? I used a puller to get the part off, and rented a HB installer from AutoZone....and it seems like it is on about 98%. Now it is REALLY hard to turn the nut that snugs the balancer up onto the crank shaft, and when I look down on the crankshaft, it looks like it needs to go another 1/4-1/2 or so.....but I don't know when to say when. Is the crankshaft supposed to be flush with the HB...when viewed from the front, or does it sit back in there a little ways? I took some photos and I hope you can see what I mean. And "yes"....the timing tab that you see MUST be made for a smaller diameter HB, because it would hit if I were bolt it up......son of a ......!!
Deja
Old Mar 7, 2010 | 05:30 PM
Secret Squirrel's Avatar
Secret Squirrel
Why not just bolt the pulley on and see if it lines up with the others?
Old Mar 7, 2010 | 05:43 PM
mydejavooo's Avatar
mydejavooo
Because I don't have any pulleys for it. I'm planning on a Gilmer belt drive setup, but I don't have it yet....so here I sit....wondering if it's on far enough....not on far enough....and I don't want to F up my crank in the process.I SHOULD have measured how far away the HB was from the block....but I guess hindsight is always 20/20.
Deja
Old Mar 7, 2010 | 07:30 PM
mydejavooo's Avatar
mydejavooo
Just measured the distance from the timing cover to the top (inside) edge of the balancer, and it's just a hair under 1"...like maybe 15/16". I've cranked on the HB installer, and I don't think I can get it any tighter. Can anyone think of a way to get it closer? I'm about at my wits end on what to do with this thing. I don't think it would have gotten as close as it is, if there were any issues with the keyways. Am I correct on that?
Deja
Old Mar 7, 2010 | 07:36 PM
thoyer's Avatar
thoyer
The first picture tells the story. The flange of the balancer should be practically flush with the end of the crankshaft when fully seated. Looks like you have a bit to go.
I would remove the balancer, check the crank for any dings / burrs as well as the keyway. Also check the inside of the balancer, should be smooth all around. Put a light coat of oil on the crank snout and try it again.
Also put a light coat of oil on the timing cover seal.
Tom
Old Mar 7, 2010 | 07:41 PM
mydejavooo's Avatar
mydejavooo
Tom
I think that's about the only thing I can do...just go at it again. Can the keyway pop out of the groove? I'm almost positive that it hasn't, but I was curious about that.
Deja
Old Mar 7, 2010 | 07:50 PM
thoyer's Avatar
thoyer
Deja
Yes it can. Since it has a semicircle shape, it could be rotated a bit and be the cause of the resistance you are getting. If it shows any signs of galling, replace it.
Tom
Old Mar 7, 2010 | 08:13 PM
Secret Squirrel
If it's of any consequence, I just went out and measured the snout and the balancer and came up with a difference of .1105"(2.8mm)
I imagine that all are not the same, but close.
Old Mar 7, 2010 | 11:16 PM
mydejavooo's Avatar
mydejavooo
Tom
Pulled the HB back off, cleaned up the crank shaft and HB housing, and deburred the keyway slot on the HB itself. Used a chainsaw file since it was small enough to fit in the groove. Cleaned it up once more and applied a generous amount of lubricant to it and the seal.....and she's on!! Thank the Maker!! The end of the crank is almost completely flush with the end of the HB...in fact, I ran out of threads on the installer...so I'm going to call it good! Thanks for your help!
Deja
Old Mar 7, 2010 | 11:24 PM
snoopykissedlucy's Avatar
snoopykissedlucy
I use half a tube of anti-seize compound on the crank snout and inner balancer....cuz it's inevitable that I will have to pull it out someday.
If you're worried that the balancer will slide out, use Locktite on the bolt.
Old Mar 8, 2010 | 07:42 PM
thoyer's Avatar
thoyer
Deja
A little lube goes a long way.................
Glad to hear it worked out.
Tom
Old Mar 8, 2010 | 07:50 PM
thoyer's Avatar
thoyer
I would not recommend using Loctite on a balancer bolt. I did a 396 for a friend once where a previous owner used loctite. We could not get the bolt out for nothing. Ended up grinding the bolt head off and scrapping the crank (it wasn't in very good shape anyway, but that is not the point.....).
A properly torqued crank bolt should stay in place. There are some thread locking compounds that may be used, but you need to pay attention to how well they "lock" the threads and their breaking strength. With that being said, I have done many big blocks over the years and never used anything but the correct torque to keep the bolt in place.
Tom
Old Mar 8, 2010 | 08:52 PM
Bowerss2's Avatar
Bowerss2
we used to use brass hammers to install those...... no problems.
just sayin
To BB Harmonic Balancer issues and more......
