pushing coolant need help
Old Mar 16, 2010 | 08:11 PM
noonie's Avatar
noonie
With an ambient temp in the 50's thee is no way that should happen.
Ambient temp is the single biggest factor in cooling.
Make sure your fan clutch is good, check that the hose plumbing is correct for the expansion tank.
600 miles for a complete rebuild or just a cam swap?
Old Mar 16, 2010 | 08:20 PM
tgensel's Avatar
tgensel
Another clue! Just ran the car at idle with the cap off and could see flow in the alum tank however I felt the rad while running and the bottom of the rad is very hot but the top half is actually cold. When I shut it down then entire rad gets hot!
Old Mar 16, 2010 | 08:23 PM
tgensel's Avatar
tgensel
600 miles after complete rebuild with no problems and then 50 miles ago coolant problem started. I changed the cam and checked the heads to be sure but no cracks found.
Old Mar 16, 2010 | 08:33 PM
noonie's Avatar
noonie
The top of the rad (hot in) should be 20 to 30° hotter than the bottom (cool out) while running.
Measure the top and bottom necks with the gun held as close as possible.
Old Mar 16, 2010 | 08:43 PM
tgensel's Avatar
tgensel
I don't have a gun right now but the top is literly cold to the touch while the bottom is very hot! When I shut it down in a few minutes the whole rad feels the same temp. Then I restart and within a few minutes of the fan runing the top gets cool again. Of course this is while its idling.
Old Mar 16, 2010 | 08:48 PM
noonie's Avatar
noonie
Isn't your top rad hose a lot hotter than the bottom one running?
Old Mar 16, 2010 | 08:59 PM
tgensel's Avatar
tgensel
Yes the top hose is very hot and the neck of the rad is hot but the more I move my hand toward the other side of the tank it gets cold quick.
Old Mar 16, 2010 | 09:07 PM
noonie's Avatar
noonie
That's much better.
The bottom hose should be much colder than the top hose too.
Old Mar 17, 2010 | 07:30 AM
tgensel's Avatar
tgensel
I'm going to change the w/pump tonite since I don't no what else to try!
