Rear Suspension Questions
Old Mar 10, 2002 | 03:28 PM
MacA1979's Avatar
MacA1979
Always Shiftin'
2025 C7 of the Year Finalist - Modified
2024 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (stock)
Default Rear Suspension Questions
I have always noticed that my Corvette ('72 LS5) rides low in the rear. If I hit a medium dip in the road my exhausts (pipes just below rear diff.) bottom out (it probably doesn't help that my fat azz is in there!! :eek: ). So today I decided to lift it up and look around to see what all I need to do back there.
Before lifting the car, I looked underneath and noticed that the leaf spring (HD 7 leaf) is sitting perfectly flat. No arch at all. Is this normal??
Right now I have it up in the air with the rear spare carrier out of the way. Other than dirty, everything looks OK. The bushings aren't too bad. Nothing looks bent. Other than some minor surface rust/scale, the trailing arms look OK. I just figured that I would post this message and see if anyones has recommendations for what I should check while under there.
My primary concern is the leaf spring. Any help would be appreciated!! :cheers:
[Modified by QikStik, 2:30 PM 3/10/2002]
Old Mar 10, 2002 | 07:07 PM
78Vette-SA's Avatar
78Vette-SA
Default Re: Rear Suspension Questions (QikStik)
On mine the rear spring had a hefty arch in it when I installed it but I believe the earlier ones were flat or near flat when installed. Might have lost it's bounce though.
One option is to pick up a longer bolt set to raise the back a little. The other would be to replace it.
Old Mar 10, 2002 | 07:19 PM
ROD NOCK's Avatar
ROD NOCK
Qik-
It's not a good thing to be bottoming-out all the time. I believe the spring should retain some of its arc under static load. After all, it's the arc that buys some spring travel. I think new springs are very inexpensive and easy to install. And as posted above extended mt bolts will buy you some time, but coupled with a new spring will improve ride/handling! From what I've seen, most rear springs (steel) last about 10 yrs under normal use and then signs of fatigue start to show. I'm looking into glass springs for my repl. I can't wait to compare the ride/handling difference! Good Luck -Rod :chevy
Old Mar 10, 2002 | 07:29 PM
Pete79L82's Avatar
Pete79L82
FE-7 springs have very little arch to them compared to a standard 9 leaf spring. An easy check is to look at the half shafts when the car is on the ground. you want them to be as level as possible. If they are angle up towards the tire then the spring is sagging.
Old Mar 10, 2002 | 07:31 PM
lyonsh's Avatar
lyonsh
Default Re: Rear Suspension Questions (ROD NOCK)
Qik-
I believe the spring should retain some of its arc under static load. After all, it's the arc that buys some spring travel. ... I'm looking into glass springs for my repl. I can't wait to compare the ride/handling difference!
I agree. And as everybody else has said, while you're under there I'd replace the bolts with the long ones to give you a wider range of ride height adjustmeht.
As to bushings, just looking okay doesn't tell you much. Get yourself a prybar and pry on the suspension parts and see how much play there is in the bushings. It's kind of a feel thing (don't get macho under there and break anything prying), but they should not have much play.
Old Mar 10, 2002 | 07:41 PM
jerryp58's Avatar
jerryp58
Default Re: Rear Suspension Questions (Pete79L82)
Hmmm... I don't think I've heard that before. Thanks for that tip Pete.
QikStik, FWIW, I noticed my 9 leaf spring was flat when I purchased my car. I replaced it with a 7 leaf and was disappointed when I saw that one was flat too. Hopefully, as others have said, that's the way the 7 leaf is supposed to be. Anyway, I did notice improvement in the ride, but with the minimal clearance (4" maybe at the exhaust under the diff) these cars have, it's easy to bottem them out. I'm not recommending it (because some say there are safety risks in rear end collisions), but I picked up about 1" to 2" in clearance when I removed my spare tire & tub. That's a lot of lost weight back there. As others have said, you might want to start with longer end bolts (or adjust the existing bolts if they're long enough) to add some clearance.
Good Luck.
Old Mar 10, 2002 | 09:21 PM
MacA1979's Avatar
MacA1979
Always Shiftin'
Default Re: Rear Suspension Questions (jerryp58)
Great information! Thanks!! I think I've just about decided to replace the spring and do a minor rear suspension overhaul. Can't afford the trailing arms right now.
Thanks again everyone!!! :cheers:
Mark
Old Mar 10, 2002 | 09:47 PM
sb69coupe's Avatar
sb69coupe
Mark, before you dive in and replace the spring, check a few things. First off, check the frame height measurements as specified in the AIM to see if the height is OK to start with. Others mentioned using longer spring bolts, but that'll move you in the opposite direction. Shorter bolts would be needed to adjust the ride height to be higher than it is now. Also, do the bushings on the spring bolts look OK? These can compress and cause the rear to sag slightly.
Shannon
Old Mar 10, 2002 | 09:53 PM
MacA1979's Avatar
MacA1979
Always Shiftin'
Default Re: Rear Suspension Questions (sb69coupe)
The spring bolt bushings do need to be replaced. A real good friend of mine is a mechanic. He is coming over tomorrow to look at it. He had a '71 LT1 a few years ago that was doing the same thing as mine. So I hope he will be able to help.
I will also check the ride height as you suggested! Thanks!!!
Mark
Old Mar 11, 2002 | 04:04 PM
norvalwilhelm's Avatar
norvalwilhelm
sb69coupe has got it right. If you want more ground clearance you want shorter bolts not longer. If you are hitting the exhaust pipe shortening the bolts will buy you some extra clearance. My fairly new 7 leaf is also flat and I would prefer a slight arch. To me a flat spring has lost it's bounce.
Old Mar 11, 2002 | 04:40 PM
Edzred72's Avatar
Edzred72
Default Re: Rear Suspension Questions (norvalwilhelm)
Replacing the old compressed spring bushings with either poly or rubber will also lift that sagging rear. If only that would work on women!! :jester :jester
Old Mar 11, 2002 | 04:56 PM
ylose's Avatar
ylose
Default Re: Rear Suspension Questions (Silvr77)
:lol: :lol: :lol: :lol: :lol:
Old Mar 11, 2002 | 07:35 PM
glen242's Avatar
glen242
According to the information I got in the GM Resto. package, minimum ground clearance @ exhaust is 4.3". This is with stock 27.5" high tires.
Old Mar 11, 2002 | 09:41 PM
Les's Avatar
Les
Thanks alot- I'm sitting here reading this at work & now everybody is looking at me wondering why I laughed out loud! :lol: :lol: :lol:
Old Mar 11, 2002 | 09:59 PM
MacA1979's Avatar
MacA1979
Always Shiftin'
Default Re: Rear Suspension Questions (Les)
I posted this same topic on the "Factory Correct Resto" forum. I also got some good feedback over there! I realized after one of the responses that I had made a Major Mistake. Here is my last response over there:
OK....I'll admit it......I'm a dumbazz!!! And thanks Chuck for helping me realize it!!
Facts:
1) The only '72 model that had the HD F41 suspension was the ZR-1 option. (per NCRS Judging Manual)
2) All other '72 models (including LS5 optioned) had the std 9 leaf spring.
3) Just got back from counting the leafs in my spring, and guess what....9 leafs!!
I had assumed since I had a big block car that the suspension was heavy duty! Well, we know what happens when we Azz/U/Me!!
Now...since I have a Standard 9 Leaf Spring, and the spring is flat (no arch at all), is it safe to believe that I need a new spring???
Chuck: Thanks for helping me see the light AND the extra two leafs!!
Mark
OK, I'm allowed this one mistake, right? :crazy:
Mark
To Rear Suspension Questions
