Need a speedometer cable
Old Mar 10, 2002 | 03:56 PM
GaryS's Avatar
GaryS
Default Need a speedometer cable
I am considering removing my 4.11 gears and putting in something more street friendly like 3.36's or 3.55's. After much discussion on the NCRS Discussion Board, I found out that I will need to remove the 90 degree adapter and change out the colored plastic gear. As a result, the speedo cable I have on my car will be too short. Any one have a nice used cable available that isn't NOS, gold plated, or ridiculously priced? ;)
Gary
Old Mar 10, 2002 | 06:50 PM
LT1driver's Avatar
LT1driver
Default Re: Need a speedometer cable (GaryS)
try your local chevy dealer. :cool: :D
Old Mar 10, 2002 | 06:52 PM
LT1driver's Avatar
LT1driver
why can't you still use your 90 degree adapter, this doesn't make sense. Also how many teeth gear do you need? :cheers:
Old Mar 11, 2002 | 12:15 AM
GaryS's Avatar
GaryS
Default Re: Need a speedometer cable (LT1driver)
Well, according to one of the experts, the adapter had a .88 adapter built in. I suppose I could use another gear to compensate, but wouldn't be much easier to go to GM chart that says with a 3.36 differential and a close ratio use a blue/greeen/tan/mauve/pink ;) gear?
The guy who is rebuilding my differential has the various transmission plastic gears.
Gary
Old Mar 11, 2002 | 12:52 AM
LT1driver's Avatar
LT1driver
didn't know that about the adapter, guess it would be easier, still try chevy you might get lucky :D
To Need a speedometer cable
