73 Horn Button
Old Mar 8, 2010 | 08:53 PM
76yellow's Avatar
76yellow
Default 73 Horn Button
I have a 73 non tilt steering wheel with none of the horn button parts. Does anyone know where I can find an exploded view showing the parts & what order they go in. The AIM manual does'nt show me much. Thanks
Old Mar 8, 2010 | 09:12 PM
oldsarge's Avatar
oldsarge
Try Willcox, to the left, they have alot of tech info available to the forum.
Old Mar 8, 2010 | 09:56 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You know.. this is a great idea for some good pics..
If you have up to the hub.. then this is what you should see...
Contact.
http://willcoxcorvette.com/product_i...oducts_id=4794
This is an aluminum stud that sticks up.. then you have the upper contact.
http://willcoxcorvette.com/product_i...oducts_id=4793
and there are three screws that hold it in..
http://willcoxcorvette.com/product_i...ducts_id=23933
But this would be a good project to take on and a question that I get all the time..
I'll have to put installing the upper horn contacts on the list of vids to do.
Willcox
Old Mar 8, 2010 | 10:06 PM
76yellow's Avatar
76yellow
Thanks Willcox.... I do have the horn button & the ring part that the button snaps into. I don't have what you just showed. I still need some sort of exploded view of all the components in the order that they go on. Thanks for your help. Zeeth
Old Mar 8, 2010 | 10:07 PM
MakoShark72's Avatar
MakoShark72
Scroll down to Standard Steering Column articles...
http://jimshea.corvettefaq.com/?page_id=4
Old Mar 8, 2010 | 10:57 PM
76yellow's Avatar
76yellow
Thanks Mako......I found it but can't download it.
Old Mar 9, 2010 | 07:59 AM
Jim Shea's Avatar
Jim Shea
See if this picture will help.
The steering wheel attaches to the hub with six screws.
Early steering wheel and hub attached to the steering column shaft with a washer and nut. (Washer shown on the above drawing.) Later assemblies no longer used the washer.
Jim
Old Mar 9, 2010 | 08:45 AM
76yellow's Avatar
76yellow
Thanks Jim, thats what I needed. Now I'll go to Willcox & get the parts I'm missing. Your very helpful !
To 73 Horn Button
