77 L82 cam specs/head specs
Old Mar 9, 2010 | 08:38 AM
cam cooper's Avatar
cam cooper
Default 77 L82 cam specs/head specs
I am upgrading a stock 77 L82,already have installed a set of Hooker headers. Would like to know the stock cam specs and head specs. Dont want to do anything over the top,just something with a little lummpy idle and increased perf. I faild to sy that I plan to change intake but stay with Qjet.
Old Mar 9, 2010 | 11:03 AM
Ganey's Avatar
Ganey
L-82 224/224 @ .050 .450/.460 114 LS
2.02 1.60 valves
Trans., rear gears, etc. should be considered for cam.
After ex., heads are good next step for L-82.
Old Mar 9, 2010 | 11:57 AM
cam cooper's Avatar
cam cooper
Thanks I thought that was the case but wanted to be sure.Would the Comp 268H be a good cam choice and would I need to change springs or would there be any clearance issues
Old Mar 9, 2010 | 03:01 PM
Ganey's Avatar
Ganey
Yes, fine w/ stock 1.5 or 1.52 rockers.
Old Mar 9, 2010 | 06:52 PM
behardt91's Avatar
behardt91
I have the comp cams 268 cam in my 79 and it seems to work well with my 350. It gives it a little lope. Just make sure to buy the comp cams oil additive when you install the camshaft. You can find it on ecklers.
Old Nov 13, 2016 | 07:49 PM
Randy Robinson's Avatar
Randy Robinson
5th Gear
I put one of these Comp 268H cams in a 76 Corvette L48 for a friend, along with an Edelbrock dual plane and headers. It was still a turd off the line. It was lame. Just more proof the L48 is a smog engine. Unless you change the heads (and maybe the pistons) there is no sense in spending money on cams, intakes, carbs and headers for an L48.
Old Nov 14, 2016 | 12:26 AM
speedreed8's Avatar
speedreed8
hopefully he figured that out 6 yrs ago
Old Nov 14, 2016 | 08:31 AM
Capt. Shark's Avatar
Capt. Shark
St. Jude 15 Year Donor
From: Into the Mystic And yet, despite the look on my face, you're still talking TN
St. Jude Donor '09 thru '25
To 77 L82 cam specs/head specs
