HEI Wiring: Pink wire optimal?
Old Mar 9, 2010 | 01:37 PM
ShaneLU97's Avatar
ShaneLU97
Default HEI Wiring: Pink wire optimal?
So I am almost done cleaning up the engine bay and wiring and I wanted to check with the all knowing forum on one item.
When utilizing an HEI dist / ignition, is the pink wire off of the front of the fuse the best source to use for the Batt terminal on the distributor?
I thought I had read this somewhere and wanted to double check.
Secondary question, what is the recommended / minimum wire gauge to use?
Shane
Old Mar 9, 2010 | 03:12 PM
1Fordman's Avatar
1Fordman
Used the IGN terminal in the fuse block with an inline fuse and ran red 12 ga. wire through the firewall to the distributor.
Old Mar 9, 2010 | 03:20 PM
ShaneLU97's Avatar
ShaneLU97
Did you connect from the front of the fuse box like in this pic?
(Disclaimer: Not my car just a pic I found in the web)
Old Mar 9, 2010 | 08:45 PM
vettehardt's Avatar
vettehardt
That's what I did.
Old Mar 10, 2010 | 09:49 AM
1Fordman's Avatar
1Fordman
That's where the red 12 ga. wire for the HEI is hooked up. With a 10 amp inline blade type fuse.
To HEI Wiring: Pink wire optimal?
