Steering Problem Please Help
Old Mar 10, 2010 | 10:41 AM
amf133's Avatar
amf133
Default Steering Problem Please Help
I drove my corvette for the first time yesterday since I have restored the interior. While driving it I realized that the steering wheel has about a 2 inch play side to side before it starts to turn the wheels. What could the problem be? How to I tighten up the steering so that it only moves when the tires move? What parts should I buy and where?
Thank You
amf133
Old Mar 10, 2010 | 11:49 AM
spoonhead76's Avatar
spoonhead76
Check out Jim Shea's papers on steering.
http://jimshea.corvettefaq.com/?page_id=4
Old Mar 10, 2010 | 05:06 PM
Vettekid1992's Avatar
Vettekid1992
turn the wheel and look to see if the pitman arm moves. thats where my sloppiness comes from
Old Mar 10, 2010 | 05:40 PM
GUSTO14's Avatar
GUSTO14
The first and easiest thing to check is the "rag-joint". Raise the hood and then open the driver's side door. Reach in and grab the steering wheel and gently move it back and forth while watching the "rag-joint". If there is any play between the steering shaft and the input shaft to the steering box, replace the "rag-joint".
The second easiest thing to do is check out the "idler arm". You'll need some help, but it's done the same way. Position yourself to be able to watch the idler arm. (Best place is from underneath, so be careful if you do that.) Have your assistant gently turn the steering wheel back and forth while you watch the idler arm. It should move smoothly and precisely. Any unnecessary movement in the idler arm means it should be replaced also.
From there, you're gonna need to follow Jim's instructions as things get a bit more difficult and complicated.
Good luck... GUSTO
Old Mar 10, 2010 | 05:57 PM
amf133's Avatar
amf133
what should i check after the idler arm?
Old Mar 10, 2010 | 06:15 PM
my 76 ray's Avatar
my 76 ray
Tie rod ends.
Old Mar 10, 2010 | 09:34 PM
larryg3's Avatar
larryg3
good advice gusto. Vettes are famous for having issues with the coupler (rag Joint)
Old Mar 10, 2010 | 10:18 PM
Ghunt's Avatar
Ghunt
You may want to check the steering box adjustment. The adajustible screw and lock nut in the center top of the steering box. that takes up the slop in the gears in the box.
Old Mar 11, 2010 | 09:15 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
Be careful adjusting the steering box, you don't want it to bind up. Make sure you mark the starting position before you start turning the screw. All good suggestions above. If you are looking for replacement components let me know.
Andrew
800-442-0335
To Steering Problem Please Help
